Speaker removal on 2008 SX230
Beachbummer
Houston TX
So, this must be really simple because I could not find a prior thread on Speaker removal with the search...
I noticed one speaker is not working (Front right) (on my weekend outing!! -YEAH! finally some weather) but when I went to attack it to examine if the issue is speaker or connection, I could not determine how to remove the speaker. The white cover seems to be snapped in placed, and its location makes it pretty hard to feel the speaker from behind...
Any tips on how to pry off this cover? otherwise reach the screws required to remove the speaker?
Thanks!!
Thanks!!
If it is a stock white grill from a Seaworthy speaker, the covers on mine were a twist lock on (counter clockwise to remove).
Beachbummer
Houston TX
Great, I'll try that. I'm pretty sure it's the original. Anything out there that is a perfect fit to the original hole?
We use the radio occasionally and at low volume so performance is not a huge factor.
Thanks!
You should measure the holes but I believe they are 6.5" speakers. Many off the shelf speakers will fit.
GTBRMC
Waukesha, WI
Thanks!
Many of us have directly replaced the OEM Seaworthy speakers with Polk db651 coaxial. They are reasonably priced, direct drop-in replacements, and they sound very good without additional amplification.
If you want to go for bigger sound, higher quality, etc, there are plenty of other options.
GTBRMC
Waukesha, WI
Beachbummer
Houston TX
So, these drop in replacements... The hole pattern actually matches the factory speaker layout? That would be nice
Thanks!
I have a couple of OEM (Seaworthy - the white ones) speakers sitting around. Shoot me a PM if you want one or two, I will just ship them to you.
EDIT: Polks DB651s are WAY nicer though.
GTBRMC
Waukesha, WI
Yes. They were for me. Hole pattern was a perfect match.
I believe, but am not 100% certain, that all 2008 SX-230s had the same uber-crappy Seaworthy OEM 6.5" speakers... and the Polk db651 were literally about 5 mins each to swap out. I used original wiring with new speakers. Very easy.
Beachbummer
Houston TX
Very nice. I'm going to confirm the speaker is indeed faulty and if so swap with this.
Thanks!
Beachbummer
Houston TX
Thanks for the offer of free OEM speakers. It might be time for a nice upgrade, but the offer is much appreciated.
Have you removed any of your stock speakers yet? If so I'd like to know if any had more mounting holes drilled than just the four needed. It may sound like a strange inquiry but this was the case with several of my speakers in the 2006 sx I had and the 2010 ls I have. So covering all of the mounting holes was a concern of mine.
Ditto! Seen it in a 2012 190 and a 2016 240, too.
Must be Yammy robots going rouge, lol.
Pretty sure the bezel on most speakers will cover any/all holes even if they don't line up. One note on the polks is you ideally need to replace the end plug on the cable to a smaller one for one of the polk terminals as they use a tiny spade connection. I tried (in my SX 230) just attaching half of the spade and it would fall off after 3-4 months....so better off just crimping the right size on at the start.
Beachbummer
Houston TX
I installed a horn on the inside with a bracket, and I fished the horn from the anchor storage, I might have loosened the speaker connection also (this just occurred to me)
I'll find out on the weekend and report back.
Beachbummer
Houston TX
So, speaker was busted. Twitter feel off as I pulled it. Noticed another Speaker was not working, and also found one of the screws was striped, so it seems prior owner tried and failed to remove.
Time to buy replacements.
Thanks for all your help!
No extra holes visible when pulled the speaker.
