Cgeetter
- Limited S
I removed both of my safety switches and used quality duct tape to keep them permanently compressed. I did that two years ago and they are still that way just hanging out underneath the hatch. Makes life so much easier.Hi MrMoose,
I still have my leaking as we discussed a month or so ago. The dealer did the entire rub rail, anchor locker, and I found and fixed the starboard shifter cable through hull fitting, and the port hot water outlet fitting (which had a pinched washer). I have done the baby powder trick and while my wife is driving the boat I watch in the back with my head lamp on. I am sure the other boaters I pass think I am wacked! Anyway, I see dripping right below the port side drive shaft hose, but when I grab the underside of the hose it's dry! So I have no idea where this dripping is coming from. Also, looks like water is also coming from under the front wall (wall behind the engines), so can't see that either. Either way I will be doing the test again, but starting with the boat tied to ther dock and progressing slowly until I get the leaking.
1.) Is there a way to disable the access hatch buttons that kill the engines when the hatch is open? Right now I made a piece of wood that I use to hold the buttons down while I'm in the back leak hunting, but I need to use that hand to get further into that area.
2.) How did they fix your through bearing? Did they have to remove the engine to get the drive shaft out?
