Dixie Highway
- Daphne, AL
- Boatless
- NA
- Other
- NA
You didn't leave the rubber insert in there right? Will definately f$$k up your engine. Let us know what you think.Last night I did the ribbon delete on out AR190. Used the RIVA ring and RIVA performance air filter. Took about an hour and was very easy. Hardest part was getting the dam filter and airbox back together. We are going out today to see how it does. I started it briefly after install and the engine sounded much throatier and deep. I liked it!!
If you use the RIVA ring the rubber insert can stay, it wraps around the ring (which replaces the ribbon).You didn't leave the rubber insert in there right? Will definately f$$k up your engine. Let us know what you think.
This is a good thread on those:@swatski please tell me more about this impeller swap...
I did the same, to me it’s a must upgrade. Easy to steer and helps me orient the wheel for true-forward when leaving the dockFinally added a "suicide knob", now I only wish I did it sooner!
@4x15mph I was thinking you may like it with your new rack and pinion steering.
