Haha. We named her "Cheat Day", dont know if im a fan. oh whale. we shall see. Thats what it will usually be for us, a cheat day with booze and snacks lol
How time consuming is the Cobra Steering install? I have a single jet SX 190 and I'm trying to figure out if it is a job I can tackle myself, or if I need to hire it out.
Takes about 35-45 minutes but its about 10 minutes worth of work. The instructions, although detailed, are a little stretched out and confusing. Now that ive done it twice, I would imagine it can be done in 10 minutes.
I finally ordered and installed new pissers. I reused the gaskets from the OEM ones and still need to trim the one around the bilge fitting. And discovered that the under seat storage was not designed to hold a 6'2" 225lb man.
I made an under seat net for rope storage. I had some elastic straps laying around, so I borrowed my daughter's sewing machine and went to town. Stitching isn't too pretty, but since I don't have to look at it, I don't care.
Mounted it under my strbd side rear seat with coax clamps. Now the cooler should fit nicely in front of the ballast, and I don't have to relocate anything from the floor of that compartment when I decide to add water.
It's not really as tight as it looks. It's actually pretty roomy once you get through the tiny opening. Getting out, well that's a bit tougher. Don't go in if you don't have the upper body strength to pull yourself out.
So, I added a second thru-hull fitting and ran the plumbing for a secondary bilge pump. I also glued the filter/basket(?) onto the bottom of the bilge. Just need to let it cure and install the pump. Then I'll wire it to the battery (I plan on having this one be only automatic. If for some reason I need to manually discharge water, I'll use the OEM pump.
Again this is in preparation for the Bimini trip which will, hopefully, still happen.
They look nice. Do yourself a favor and add SS washers behind these 6 screws. Over time they could pull thru the plastic fins. Adding these prevents that from happening. Ask me how I know.
The ones I bought are 3 inch, but they also come in 3.25. - A bit spendy, $125, but then again, it's going on a boat so it requires the 75% boat upcharge!
