JasonSchoenrock
- North Carolina - Lake Norman
- Limited S
I finally got my 2016 LS back to my local dealer and one item on the list was for him to fix the port side throttle drop issue that's been there since the beginning (I'm familiar with the fix posted here but it's more than I wanted to handle as DIY). The dealer came back and said:
Is this true? Should I just let them run like that? I don't notice any pulling when I have the RPMs synced up manually. Any insight is appreciated!
"My tech Just got off the phone With Tray from Yamaha and he sent him the forum you have sent me, Yamaha STATES that the port motor will drop up to 300 rpm, its designed to do that be casuse [SIC] there are two different pitch props on the boat. If they would run the same rpm it would pull to one side. I hope this helps."
