itsdgm
- Rancho Santa Margarita, California
Looks great Mel.
It probably will not be an issue for you, but a 50a breaker is designed to trip at 80% of Max amperage or around 40 amps as I said probably not an issue, you would have to plug in a lot of stuff to reach 40.I am still working on wiring...
I removed the 100A service panel and installed the new 200A service panel in its place in the old boat barn. I have all the wiring pulled...2GA with a double pole 100A breaker in the 200A box to feed the RV barn's 100A panel. I HATE PULLING HEAVY GA WIRE!!! I have the outdoor pedestal we have been using, installed permanently now to the side of the entrance to the new barn for outdoor needs. Running the 6GA for the pedestal where I moved it to, required cutting the 6GA cable and splicing it to add another 30', and that is something I had not done before. It puts me at the limit for 6GA but that is ok, it will never pull 100% of the 50A load. And it is protected with a 50A double pole breaker in the service panel, and a 50A double pole breaker in the pedestal. It is run off of the main 200A service panel. If I had to hire an electrician to do all this work, it would have been as much as foaming the new RV barn! The wiring I now have left is just within the RV barn itself. I will have a walk door light above it, as well as a light above both the overhead garage doors. I am using new 4' LED fixtures that provide equivalent illumination to 80 watts of florescent lighting each, but only draw a total of 18W each...and installing 4 down each side of the barn ceiling for a total of 8 of those fixtures. It should provide good illumination. It is high up however, at about 13' I think. And they will be angled toward the coach by the pitch of the roof. If this doesn't provide adequate illumination, I will lower them at some point. But the coach is almost 12' tall to the roof line and another foot above that for a/c and other roof mounted items. So my thoughts were to make sure the roof was well illuminated and at the same time, the floor and wall area of both the barn and the coach. I think that I may need at least two more of these fixtures on the front and back to illuminate the rear and front of the coach if needed. But...with garage doors on both ends, if they are open, it blocks the ceiling and any lighting mounted there. So any lighting needs to be suspended below the open door. I think maybe a flexible gooseneck lamp mounted on the wall would serve to illuminate any task lighting needed there as opposed to trying to get general lighting to cover it.
A note to any of you with those garage or utility 4' fixtures that are florescent...KEEP THEM! For literally a buck or two, you can change the ends the tubes twist into, they are called tombstones, and you need non-shunted tombstones to use the new LED tubes. You cut out the ballast box and use the existing wiring to convert them to LED. I converted my house over and had 24 of these fixtures in my garages, utility, and closets. I ordered 50 LED tubes on eBay for less than $8 each, replaced the florescent, have two spares, and have clean, instant, non flicker, non temperature affected, bright white lighting. I wish I could have found a dozen of these fixtures surplus to put in the old barn and the new RV barn. Buying them for $30 each didn't make sense and then spending $2 converting them, so I bought the fixtures I bought that don't use the tubes, and just have the same strip LED inside them. So if you have these fixtures in your closets or utility rooms and garages, you are going to want to keep them and convert them when you need to replace bulbs or ballasts, as it is cheaper all the way around.
In addition to the lighting runs in the new barn, I have to run the wiring for 20A 110V outlets. My plan calls for 4 outlet boxes on each side of the barn, and two on each end. All of these need the wiring protected. The wiring will be behind the OSB composite plywood, I am lining the interior barn walls with. I could just run the romex cable behind the walls without putting in conduit. Several have mentioned code to me, and interior buildings don't require conduit unless the wiring is exposed. But in a barn, it is iffy as to intent too. In my existing barn, I ran the romex on the rafters and stapled it down without concern and behind the OSB on the walls. In the new barn, I don't have surfaces to mount as easily to, and that has me thinking conduit. I will use the conduit for exposed runs just for a clean look. But behind the walls, I am not convinced it is the best option. I have talked about this before, and don't know if any of you have any ideas you might want to share here. My thoughts have been to just lay the wiring behind the conduit in the foam and cover with the OSB...done. But if you ever need to run something else, extend something, or make a change, you can't easily do that without removing the OSB from the wall in question. That is what I do in the old barn when needed, just like adding the new run to the new barn.
I think maybe some may ask why I post this thread in a boat forum. Well, honestly, it is perfectly applied to a boat barn, or even a home improvement project. And we all have them. And just like everything else here, it is what we share that makes this forum so great. I have learned a huge amount from jetboaters over the years, and giving back is a pleasure! So I hope this helps a few of you to find solutions and adaptations to help you with your projects in the years to come!
I used a sissor lift and really just pushed wire through @buckbuckLooking good Mel. I'll bet your anxious to get the foam installed.
Just curious, how did you pull the wire through the j-boxes mounted up high next to the overhead door?
