Troy JK
- 242X E-Series
Since I won’t be using the ballast system, why not use the pumps as bilge pump? Hopefully I won’t ever need to remove that much water that fast but they’re there. Never used the system at all but the Pumps must be reversible to also drain the bladders. With only two wires im guessing that to Pump out the polarity is reversed.
anyone try this?
anyone try this?
