WickedPorter
- Polk City, IA
I was wondering the exact same thing when I brought her home tonight and looked, trying to figure out what happened to the fresh air vents/cut outs at the back of the engine bay (as in previous MY). They are gone...! There are no vents!It seems to me that the engine compartment lacks a way to get enough fresh air in with how well they are sealed up now. I wonder if flipping the blowers over and turning them on would be enough to get the engines to perform better? Obviously only for a short duration test and I can't say that I would try it myself but just a thought to see if the engines are fresh air starved (more o2 in fresh air).
I don't believe there is anyway to adjust your throttles with the Eseries or X series. Everything is drive by wire so hopefully we will see someone offer a programmer that give more power!! As for your rpms, it seems like most of us are between 7400-7600 depending on passengers, fuel, coolers full of beer etc.I picked up a 2016 Limited S E-Series a few weeks ago. It was used as a sales demo (got a pretty good deal on it) with 13 hours at delivery. I'm seeing the max RPM of around 7400 on both engines. The net effect is 46-48 mph max depending on load. It's a non-CARB model (132kw/177HP). Does anyone know if the E-series boats have a throttle adjustment like the non-e-series do? There doesn't seem to be a service manual available yet.
Right, but there is no extra openings in the stern to allow airflow? I can't figure out how does fresh air get in if the blower is off, other than through gaps.Just an FYI the blowers vent out under the rear facing seat backs on the stern.
It never crossed my mind that the engine bay could be so airtight that restricted air flow would be a problem, especially with all the wires, cables and tubing running in and out of it. Now if we can come up with a way to force feed cool air right into the throttle bodies.@Bryan L - I can see your point in theblower ducting when the blowers are off but what about when they are running? Must say I am not sure where the air is all coming in from but it is getting in there. Those numbers seem just a tad low even for a carb boat. Have you tried the throttle adjustment? When was the last time the hull was cleaned? Have you ever sucked something into the impellers? Ever driven the boat with just you in it?
You are correct, @Dough! The house sits around 4200 and we usually trailer the boat to either Pineview Res. (~5000) or Bear Lake (~6000). I hope to get a chance to take the boat back east and open her up, just so I can cackle like I just robbed an 1800's Wells Fargo stagecoach. In the meantime, I'll remain jealous of those who can hit the 7500rpm/50mph range and live at sea level!Bryan is at 4200 feet.
@sysinu has been a huge help in this regard. He lives and boats at an even higher elevation, so he's been there and done that. The throttle body spacers just arrived today and I will be repitching the impellers in the spring. I'm actually expecting a small increase in top end, acceleration and fuel economy. I will try anything to help this boat breathe better and turn those screws as efficiently as possible.Throttle body spacers and elevation pitched impellers may help.
Tested that today, seems to be no problem with extra soundproofing. The weather was cool and dry which helps but at least I can rule out any serious air starvation.@swatski- I tested wot with the engine hatch held ajar. No difference in rpms so not air starved stock. Depending on how tight you make things with your sound proofing that could become a factor though.
yes I did use the RIVA rings/spacers this time. I seriously doubt those are critical, but figured might as well at $40 a piece. And I was able to append those to my SeaDek order (to avoid scrutiny).@swatski - When you did the ribbon delete did you throw in those riva rings or just straight delete?
