Pretty sure 3/8" ID. Someone could double check me on your boat. I bought some just haven't installed it yet.
Yes, the rod holder goes really deep into the space - need to figure that out. On the 190 though, water would most likely flow directly into the bilge even without the hose.@poordealguy Looks like you have almost a kink in that hose in the picture right where it connects.
Wouldn’t there be standing water in the rod holder part?Silicone itThink I may just take that route tomorrow.
1/2” OD - 3/8” ID...I took the rod/cup holder with me to HD to test fit - 10 ft for ~$5.XX...
Maybe flip that one around....never seen a hose bigger on the inside than outside.Sorry - that was [HASH=5843]#fakenews[/HASH]...it’s 5/8” ID and 1/2” OD...
Long day...corrected... ?Maybe flip that one around....never seen a hose bigger on the inside than outside.
and fiberglass shards on my hands and arms.
@Maineiac for your specific spot there, I'd take out the cup holder, take it into Home Depot with you, and find some poly tubing like you would use for the water line to a refrigerator (it's opaque white stiffer tubing) . Get a few fittings, likely in that same aisle, and fab up something with that. Any area that kinks, cut it and use a fitting to keep things heading in the direction you want it to go.
I'd use the silicone to seal the tubing to the nipple on the cup holder. Put it on the nipple only, then slip the tubing on to keep it clean and open.
If you really want to make it simple, drill a hole in the floor in that compartment, fit a rubber grommet into that hole, and feed the hose from the cup holder into the grommet and let a few inches dangle past that so that it won't pull out. What little water that will pass through there will dump into the bilge, to be drained when you pull the plug for the day.
If you EVER get any water coming back up, you'll never even realize it, because you'll be more concerned at that point by your sinking boat!
Just drill away from the outer sidewall of that compartment
