Winterizing motors
Philip
Long Island NY
the time is approaching to winterize boat. Any tips on antifreeze flush in motors? Live in NY and rather have peace of mind. I seen a 5 gallon jug with attachment from west marine ? Any tips appreciated.
Bruce
Royal, AR
Trm1765
Red Wing MN
Limited
Pull boat out of water, rev it up a few times, engine is wnterized.. I do ad gas stabilizer and some clean up but no need for antifreeze in engine. I live in Minnesota and have done this every winter.
buckbuck
Texas
No need for the engines but I do put some through the ballast system. I live in Northern IL.
GiddYupJoe
Beavercreek, Ohio
Is it pretty normal to have a rough engine start in the spring? I have noticed this for the past couple seasons. Everything works it's self out after the first fire. Just curious.
Trm1765
Red Wing MN
Limited
I agree, anything with water like the ballast system, the water tanks and items like that need to be winterized, but there is no water left in the engines.
Philip
Long Island NY
It's hard to believe that no water is left in there. It's cheap insurance.
jetboater4life
Rochester, MN 55901
I just grab a friend and have them gravity feed it into a funel that is hooked up to a hose connected to the flush port. I pinch off the water inlet hose to make sure it all goes through the engines cooling. I fog at the same time. One gallon of antifreeze takes about a minute which is just about the right time to put a half can of fogging spray through the four air intakes on the engine. Super simple super fast, couldn't be any easier. I also put antifreeze in my ballast bags and run my ballast drain. Full tank of gas with marine stabil and it's to bed for the winter.
GiddYupJoe
Beavercreek, Ohio
While we are on topic of winterization, I have a quick question. I have two quarts of Yamalube 10W-40 left over from last winters oil change and just found out that our local marina is sold out. I will have to just grab some 10W-40 from the auto-parts store since I am winterizing this weekend.
Is it fine to mix the Yamalube with the new stuff I buy or should I stay consistent? Assuming all oil is conventional.
McMark
Monongahela, PA
Why not just get a couple more quarts from Amazon or somewhere? My OCD self wouldn't mix. I like the Yamaha oil
The only place water remains is in the bottom of the large round water boxes (perhap 1/2" to 1" depending on how much you rev the engines and how high you tilt the boat). This water can freeze, but since it is in a rounded container, it doesn't break anything. Many of us, myself included, have never put an ounce of antifreeze in our boats to winterize them and have had no issues (I used to live in Illinois).
You don't list your boat type/model....so I HOPE you are talking about a Yamaha Jet boat. Other jet boats have different set ups.....this advice only applies to YAMAHA boats!
I recommend you go here:
https://jetboaters.net/account/
and add you boat info and location (generic city/state or zip) so you get the best benefit from membership on the forum.
Jluzader
Wilmington, DE 19810
Being a new owner and first winter if that's really the case than I can send my kit back. So it's just flush, fog, after fog restart and blow out water then spray in plug holes? Then apply Yamaha Silicon Protectant and Lubercant to engines. Replace old plugs, start after winter burn junk out then put new plus and change oil?
If that's the case then it saves even more cash and time.
Bruce
Royal, AR
Antifreeze does not do anything for Yamaha boats.
Adrian242
canada
Hi guys I have the same motor in my waverunner and you don't need to put antifreeze in the engines water jacket. You don't even have to fog the engine really but I guess it cant hurt. I wouldn't even fog it till the motors shut off but that's just me. By running the motor and giving it a few squirts of throttle is fine. As long as you change your oil regularly and with Yamaha genuine oil these motors are pretty bullet proof. Hope this helps
Rodney Findley
Cumming, GA
I also plan on spraying in some of the fogging oil before I finally shut the engines down for the winter... You can also refer to jetboat pilot's YouTube channel for the process. However, the filling you boat with fuel part is not that necessary, the ethanol in regular pump gas has some contence to help absorb fumes so I am sticking with 1\4 tank of 89 octane for the winter.
Big Shasta
Panama City Beach, FL
bad idea. The open area in the tank will allow condensation during temperature changes. You don't want your fuel to be able to absorb water.... and unfortunately ethanol loves to absorb water. It will phase separate and gunk up the fuel system. You might be fine but you're increasing your risk for sure.
The best way to do it is E0 fuel and a full tank. Either way, I would add some stabil and stabil for ethanol if you're stuck with E10.
zelone
Croydon, PA
Add stabil, blow out water by revving engine dry every few days for a week or two, and I pull the spark plugs, spray in some fogging oil, crank over and respray. Reinstall plugs and count down the days until spring! I also pull the batteries and trickle charge them over the winter. Been doing this process for 8 years with no issues, and it gets cold here.
Rodney Findley
Cumming, GA
Counting down the days have begun!
