well, that's not good, lol. I'm sure you can get a replacement with a stopper of some kind?I wish it was just the base. My port side pin will twist and fall out while boating
My starboard side pin's safety pin was too short and the spring/ball was jammed in so the whole thing would just fall out (did this in the 2018 Bimini crossing). Dealer replaced the pin.I wish it was just the base. My port side pin will twist and fall out while boating
I have the same issue.I have 2 new white bushings on back order. I have adjusted the set screw ball detente. I knew it was a bit loose but after I fallowed Swatski 's sound deadening post all I hear now is the tower popping and creaking.
The base. I've compared the pin's on both sides and the port side is noticeably more loose than the starboard side.Do you know if the sound is coming from the bimini pivot or the base ? If its the bimini pivot point i did take a small black cord and pulled it down to separate the metal to metal contact this with some lube spayed first seemed to help,.
Not sure i will call and get it. I knocked the white bushing out and turned it 90 deg. That helped for the rest of last year. but the damage had been done. the movement stretched the aluminum pin holes.I have the same issue.
Do you have a part number you could share with me?
F5V-U081L-00-00 | . BUSHING |
@Troch1 I have the same rattle, where do you get to those nuts from? Under the seat and behind seat back?Just to bring this back to life, checked my ‘18 242x tower bolts today for the first time and all 6 nuts were barely hand tight. Get that deep 3/4” socket and 24 inch extension ASAP!
Need 1 per tower side. So 2.... this fixed my tower.
F5V-U081L-00-00. BUSHING
yep, get into the under-seat storage area and look up on the starboard side. Three nuts per side, iirc. The port side was done blind (pain in the ass) as I didn’t remove the batteries, nor the divider for the ballast bag.@Troch1 I have the same rattle, where do you get to those nuts from? Under the seat and behind seat back?
