SamCF
- Greenville, SC
- SX192
Here is the parts list for the Trim and Reverse bucket install.
All of these parts were for a 2015 FX Waverunner. There are other Waverunners with different Venturi nozzles if you want to match up what is in your boat. I recommend this one for better hole shot.
The bucket shift linkage will have to be moved to the side of the pump. Using the stock location did not allow for enough range of movement in the bucket. 3/4" bit and some 3M 4200... it won't hurt too bad. I used an old bilge fitting to plug the old hole. The mounting point for the shift linkage to the bucket is very important as that controls your range of motion and Neutral position.
https://www.yamahapartshouse.com/oemparts/a/yam/54206ad9f87002132cdd7199/jet-unit-1
https://www.yamahapartshouse.com/oemparts/a/yam/54206af4f87002132cdd719b/jet-unit-3
Nozzle: 6BH-R1318-01-00 $88.82
Ring,Trim: 6AN-R1190-00-00 $15.50
Gate, Reverse: 6ET-R1314-01-00 $138.88
Bracket 1: 6ET-R1341-00-00 $11.59
Bracket 2: 6ET-R1342-00-00 $11.82
Nozzle, Deflector: 6S5-R1313-01-00 $23.26 (I used the Dean's Team extended nozzle. Riva also has one.)
Associated bolts, washers and spacers for mounting.
Reversing polarity momentary switch to control trim tab actuator.
8" aluminum stock for trim control bracket.
Trim tab actuator for control, or use a turnbuckle or other fixed/adjustable mount for the trim ring.
Twin engine boats can probably use one actuator to control both trim rings with the right bracket.
https://www.amazon.com/Lenco-15054-...qid=1526047531&sr=8-3&keywords=lenco+actuator
I can't describe just how good this drives now. The low speed wandering is gone, excellent control and speed in reverse, and this is with no fins. It really feels like I added power steering. The wake is much cleaner at surfing speed with the trim down. I love the way the boat feels at speed with the trim up.
I just started using the GoPro and iMovie so the video is pretty basic.
