bobholthaus
- St. Louis, Missouri
- 242 Limited S E-Series
I broke my anchor light clean off this weekend going under an extremely low train bridge. The plastic base is all that’s left (with a single wire sticking out). If anyone can answer any of the following,I’d appreciate it:
1. Is the unit grounded on the Bimini cage? There’s no negative wire by the base of this broken light.
2. Does anyone knows of a folding LED replacement with the same bolt pattern?
3. When I go to Lake Michigan each summer, we’ve decided we don’t need the Bimini top at all, so next summer I will take it off (metal and all). So I need to add a second light to the top of my tower. Does anyone know the part number on the Deutsch connector for the wiring so that I can make my own second unit it for that vacation?
Thanks in advance. And the bridge was so low, we had the tower folded all the way down and the Bimini top released (and being held horizontally). It was scary, and the last time we do that (first time at Lake Springfield in Springfield, Illinois).
