Another Clean-Out Plug Thread
I had the boat out this weekend. The cleanouts were plum full of water. I haven't yet applied the bees wax. Any chance the water passing the plugs is overflowing into the storage area, down the drains, and then is pumped out the bilge? Maybe the pesky anchor storage locker drain is getting a worse rap that it deserves?
I promise you, that anchor locker drain has a well deserved reputation. True, it may not be in every case, but it's definitely one of the first (and easiest) things to check. The drink holders would be the easiest, but least problematic, the cleanout tray would be next, the scupper would follow, the ski locker fitting, and lastly, the rub rail.
The cleanout plugs should be regular maintenance items, with additional attention to details, as they are contributors as well, but you should be touching those at least twice each outing.
I have a 2020 242 SE i bought new: Last fall when I had the winterization done, the dealer rebuilt both of my plugs because they were becoming almost impossible to get out. He told me that I should take them out at every outing so that they don’t swell. He also sold me some Yamaha Marine grease to use down in there; see pic. It’s blue and appears that it will be a complete mess anytime I have to use those drain plugs to dislodge the stuff I get in there from the Mississippi river. I’m assuming the beeswax would be a little cleaner and would replace the Yamaha marine grease he suggested I use? Also, do I apply the grease/beeswax onto to the metal parts of the plug (outside edge), or do I put it on the rubber lower part as well? Thanks in advance.
Btw: anchor locker lack of draining: am I supposed to do something about that? A link to a post would be appreciated.
I have a 2020 242 SD i bought new: Last fall when I had the winterization done, the dealer rebuilt both of my plugs because they were becoming almost impossible to get out. He told me that I should take them out at every outing so that they don’t swell. He also sold me some Yamaha Marine grease to use down in there; see pic. It’s blue and appears that it will be a complete mess anytime I have to use those drain plugs to dislodge the stuff I get in there from the Mississippi river. I’m assuming the beeswax would be a little cleaner and would replace the Yamaha marine grease he suggested I use? Also, do I apply the grease/beeswax onto to the metal parts of the plug (outside edge), or do I put it on the rubber lower part as well? Thanks in advance.
The grease is an example of "when all you have is a hammer, everything looks like a nail". Yes, it will work, but no, it's not the best solution. Save that grease for maintenance items on the boat where that grease is called for, it'll be more useful there.
@FSH 210 Sport has some great info on his results and where he applied it, not sure if he posted about it, but he'll see this
The anchor locker has about an inch or two of water in it, right? I remove the leftover with a sponge, takes a few seconds. It's one additional reason I think it's a stupid design and a hassle that didn't need to be created in the first place
Thank you for the reply. Does anyone make a tube of beeswax that would easier to dispense/store (with a lid?) Also, how often should I be putting it on?
This is my first boat; what else should I be greasing? I’m only using it 40+ hours a year. It still looks almost brand new, ha.
I haven’t looked in my anchor locker lately. I’ll check that for water. It does seem to be wet in there at times; it’s an open drain to the front, correct? Should I cork it or something inside to keep it dry? I hardly ever use an anchor.
I have used bees wax forever If you want a tube of it put the ring in an old pan and warm it up until it is a liquid then use an old paper towel cardboard tube and block it off on one end, I use metal tape on and around the bottom . have the tube sitting in another container just to be safe and pour the liquid wax into the cardboard tube let it cool off and you are all set. Resembles a grease gun tube.
Amazon may make a tube, or follow Jeff's advice on how to make your own "tube". Use some gloves, and just apply it by hand when you start to feel like you need to reapply it. Your own sense of when to apply it is perfectly fine.
Find the owners manual, and see what they lay out for maintenance, they should indicate what needs greasing, when, and how often to check and reapply. Not sure what the grease is that you were sold, let us know, and we'll have a better idea. I've tried using it on my wife, but the noise hasn't stopped ??
Yes, it's an open hole to the outside. Get a look inside to see if it's a good seal, or if it looks like they drilled the hole with a .45 slug. If you have the crappy drilling and the short anchor locker drain, you won't need to ask us, it will be crystal clear. If so, there's a link in my signature line for how I addressed it. Follow the link and the steps to do the job Yamaha should have done in the first place, if they wanted to add a hole to let water into the boat
First the anchor locker … read Drew’s thread here. https://jetboaters.net/threads/replaced-my-anchor-locker-drain-fitting-due-to-leaks.32891/
I highly recommend you replace the anchor locker drain fitting with a stainless fitting. Then if you look at post #125 in that thread you’ll see the plug I use in mine most of the time. My drain is very close to the water line and I have to deal with AIS so I don’t need any lake water getting in there.
These anchor locker drains are notorious for letting water into the bilge. I took some close up pics of mine so you’ll see what’s up with that.
The toilet bowl wax works great at sealing the clean out plugs. Recently I tried it for the first time and after driving the boat hard for a hour there was zero water in the wells. Yes I packed the little trough where the seal sits with wax.
I would not put any marine grease on those clean out plugs, the wax was messy enough I can’t image what water proof grease would be like. If you want to keep them working smoothly give them a healthy dose of silicone spray once and while where the parts rotate.
If you have not done so yet buy a service manual. Lots of great maintenance stuff in there and you should have already greased the intermediate bearings, be careful, read the manual carefully.
One thing @FSH 210 Sport learned the hard way (sorry I caught you too late), the toilet bowl wax is fairly easy to apply, the warmth of your hand should be enough to loosen it up for application. No need to warm it up in the sun ?
Yesssss. It was a bit messy in my first go but hey it worked.
Probably a dumb question, but...
Are people whose boats live in wet slips taking out the cleanout plug after each use, and leaving it out? I thought I read somewhere that you should leave the plug in if your boat lives in the water. I didn't take mine out at all last season except when I needed to pull weeds out of the impeller shaft.
Mine lives on a lift (if that counts for your question) and yes I take mine out every time. It's just sort of on the mental checklist and with my declining mental faculties it's easier than trying to remember when I last took it out. I left them in for a month once and they were noticeably harder to pull so for the little effort it's every time. Well almost every time. I do it as i pull the cover on now. If I'm coming right back the next morning I would leave them in, other wise I pull them
Oh wow, definitely going to try this Beeswax trick! My ports have been leaking since day one.. as some have said on here, when I spoke to the dealer about the issue, they stated, it’s water coming up over the stern….. ummm, no it’s not!….(on the new 25’ boats, that port ledge is WAY higher than my old ‘05 230HO) Then they said they’ve never heard of an issue with the port seals leaking…. Even though I’ve read many threads on line of exactly this!…. Mine only leaks when going 35mph plus…. But mine leaks enough to fill the tray and eventually makes its way into the bilge…. Then I see about 3-5 gallons of water being pumped out!…. Truly frustrating! Wish me luck with the toilet seal wax!….
I have been having a problem with water getting in the bilge as well. What you described is exactly when I see water fill in mine. I have sealed everything I can and even rode with the tray off, holding the kill switch to see if I could see a leak. Nothing leaking inside. This is the only thing I can think of as to how water is getting in.
Did the bees wax seem to help if fix the leak?
Have you tried the baby powder trick? There is a thread around here somewhere on it, but basically someone used the powder around the bilge, then took a little cruise and opened the bilge to see where the streaks were in the powder. Problem on these boats is that there are so many options... anchor locker drain, rub rail, cleanout port tray, cup holders, etc.
Other option would be the 'fill the bilge with water' while it is out of the water trick (but that to me seems much more involved).
I have seen the baby powder thread but fig since the bilge sits higher than the lowest part of the transom (2018 SX190) by time the water gets to the bilge it will just wash it around.
I took it out yesterday for first time this season and while it was completely dry I rode around with tray off to see. No water was coming in anywhere (not even filling clean out tube nor over flow when slowed fast) until I had it at higher rpm (7k). Water then filled the clean out tube fast so had to stop just before it overflowed and filled the boat. Out of all the different ways of looking, checking and testing (even had two shops try to find where water was coming in) @DaveShip55 described what is happening with mine exactly. I am hoping that the bees wax idea worked.
I put the Bees Wax on my clean-out ports, but now every time I twist and open the port, it sounds like a toilet flushing...
As long as the s##t goes down and not in I will take it as a win
To be honest, didn’t seem to help any, and it was kind of a PIA to apply, and then remove. lol! So I’ve just gone back to spraying a good silicone spray on the rubber seal..
I’ve tried Pool grease, silicone spray, and the bees wax, nothing seems to do the trick. I’ve actually just gotten used to the bilge pumping out the excess water when going over like 40 mph. Maybe this season I’ll buy new rubber seals and see if that’ll help. It’s a bit frustrating, but I should have just brought it to the dealership and have them looks at it, but they require a ‘test’ ride, and it’s just hard for me to arrange that since I store the boat in Havasu, but live in So Cal.
Ok. Thank you. I am going to try the wax tomorrow and am prob going to rebuild the plug. If those don't work, then yeah, prob going to chalk it up as "it is what it is". It doesn't seem to hurt the performance and it hasn't sunk. Thanks for the feedback. We can definitely say it is something we deal with across the country...I am in Atlanta.
That’s for sure! I’ve seen a lot of people with the exact same issue, and what’s funny, when you mention it to the dealership, they say’ “Hmmm, I’ve never heard of that happening!”…. LMAO!…. I even spoke to a Yamaha Rep at the local boat show, and he too said he’s never heard of anyone having that issue.
Gotta love the mechanic at the dealership in Lake Havasu, tells me it’s water coming over the back when you come to a stop…. LMAO!…. With the new boats, and the height of the rear hatch where the clean out plugs are, the water has NEVER come up that high…. Which I told him, and he rolled his eyes at me! LOL!
