PreciousMetals
- Acworth, GA
- Limited S
I just heard back from them, they said the fogging straw was stuck in the throttle body.... They are going to put it back together and water test. He didnt want to completely clear me, but he said I should be good to go. (Crossing fingers!!)@RobA, glad you ran into this issue now, and not on the big water. As you know, I had oil cooler issues I found a few weeks back and thought I might have to cancel if I had to cover the cost.
WOW !~ thats ..ummm.....fortunate ?!?!?!?! I'm surprised you got one good run out of it, ...then it croaked. melted plastic cooled off I guess?......got into places?I just heard back from them, they said the fogging straw was stuck in the throttle body.... They are going to put it back together and water test. He didnt want to completely clear me, but he said I should be good to go. (Crossing fingers!!)
When I fogged last year, I lost one of the straws... I thought it just fell into the murky bilge water below...well I guess I was wrong! Its a double edged sword because this obviously wont be covered under warranty, but at least I know my engine isnt completely screwed...
Dont know, they are water testing it and going to call me back. I'm not sure it would have melted... the air going in the intake should be close to the ambient temp in the engine hatch/outside air.WOW !~ thats ..ummm.....fortunate ?!?!?!?! I'm surprised you got one good run out of it, ...then it croaked. melted plastic cooled off I guess?......got into places?
sorry Rob. You said throttle body, and my brain read cylinders.......Last year when I fogged I stared at the spark plug wells and said "nope. not using the straw".....thus the brain crampDont know, they are water testing it and going to call me back. I'm not sure it would have melted... the air going in the intake should be close to the ambient temp in the engine hatch/outside air.
That was exactly it, still waiting for confirmation that everything is good. Waiting anxiously.....Probably a Throttle Position Sensor error or if it is fly by wire an error on the position and servo being out of sync!!! That's fortunate considering the things it COULD have been!
Noted thanks! I think I might just run a power wire to the battery, after all the radio is a very important part of being safe out there.Be careful where you tap into a power source ! When you key the mic it draws more per than just having the radio on !! Right @upperdeck =)
No kidding...Be careful where you tap into a power source ! When you key the mic it draws more per than just having the radio on !! Right @upperdeck =)
I ran a duplex ANCOR wire to a fuse block. http://www.amazon.com/gp/product/B001P6FTHC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 and ran a dedicated ground and fused power to the fuse block. http://www.westmarine.com/ancor-marine--duplex-wire-by-the-foot--P009_274_003_002For you guys that have a radio, or will be installing, are you running positve and negative over to the battery, or just tapping into the helm somewhere for the negative?
