Madcityami
- Madison, WI
- SX
Sorry for another engine overheat thread. I did read a bunch of threads but am in denial that they apply to me because most of them ended in corrosion related to running on salt water. I do not run on salt water, but I do run on a lake where the weeds look like they are from little shop of horrors. I’ll try to keep this to a few pointed questions.
Background: Last night, I changed the impellers and housings. Today, put the boat on the water, checked the oil and port engine temp warning went on after about 200 yards at no wake speed. I verified nothing coming out of pisser #1 so I shut it down and headed back to dock on the other engine. I had the boat pulled out of the water. There were some weeds wrapped around the impeller in my 400 yard journey, but pretty minor compared to what I've seen in the past without issues. I ran the engine on the hose...which in my mind would rule out any possibility of my impeller job somehow botching the cooling flow. It ran fine on the hose idle, but when I bumped up to 4k RPM, I got the overheat again pretty quick.
Question 1: Does this look like water is coming out of all the right places? The engine was running at idle and there was slight spitting from the pisser. It comes out of the top port after about 10 seconds.
Question 2: After about 10 seconds in, it appears the water out of the top port has either white smoke or steam. Should I be concerned?
Question 3: Is it possible (given the volume of water you see coming out in the video), that the hose did not provide sufficient water volume to keep the engine cool at higher RPMs? 4k didn't seem crazy to me, but I'm new to all of this. The pressure is not great from this hose to begin with.
Question 4: Does this theory seem plausible?:
- Somehow, weeds covered the water intake from the start
- 200 yards of no pisser time was long enough to get the temp warning
- whatever was covering the intake came off when the boat was pulled from the water
- My on-hose overheat was due to RPMs too high for water volume
- I probably could have just put it back on the water and had a great anniversary-eve afternoon on the water
