HangOutdoors
- Royal Oak, MI
@FSH 210 Sport You do know the Fish won't know the difference
@FSH 210 Sport You do know the Fish won't know the difference![]()
Update:
It’s been a bit, and a lot of work since my last post.
In the end I went with 100Ah Battle Born Batteries for both the trolling motor and an upgraded house battery.
These batteries have the internal heating that I need for the shoulder seasons here in the upper Mid West. The internal heating has to have a small wire attached from the positive post to a 4mm screw on top of the battery to initialize the heating function, from there it is automatic in that once the internal temperature of the battery reaches 35* the heaters turn on, then turn off at 45*, the heaters run off of the batteries‘ own power, while consumption is not heavy it is there. According to bb‘s literature, a fully charged battery in an insulated battery box will have enough power to run the Internal heating for 4 days. Also, the bb‘s BMS will not allow the battery to charge if it is too cold. The down side is that if the battery is left in the cold without a charger hooked to it, it will run the battery down to where the BMS will cut off the battery at 10.8 volts. I was hoping to find a fully automatic heating system in a battery, the ReLion does have a fully automatic heating system that is powered off of the battery charger, but it’s BMS will not stop charging if it is too cold, and most importantly the ReLion heated batteries cannot be connected in series. So, the way I look at is that the on board chargers will be plugged in all the time anyway so it is not an issue.
The other thing I found out yesterday was that you cannot have an AGM start battery and a LiFePO4 house battery and leave the OEM DSVR relay as it comes from the factory. The resting voltage of the LIFePO4 battery is above the DSVR‘s activation threshold of 13.4 volts, causing the relay to close paralleling the AGM and LIFePO4 battery. And, since the voltage is higher on the LiFePO4 battery it will start trying to charge the AGM. So, you have to cut the little red wire in the back of the DSVR relay and hook it up to either a manual switch or an ignition hot to activate the DSVR relay. Since I had just added some switches for the new bilge pump and raw water washdown pump, I also had installed a spare which I used for the DVSR supply voltage… works like a charm. Going forward I will be adding a time delay TD relay with 5 minutes of delay after the ignition switch is turned on to allow the AGM start battery to come up to and go higher than the LiFePO4 battery, once the AGM comes up to either equal to the LiFePO4 battery, the charging systems will start charging the LiFePO4 battery.
Note: Something else I discovered about the BEP DSVR, you know how their literature says that it will charge the start battery first? Well that is partly true because the DVSR relay will be open after floating for a while and using the house battery to power stuff. As it turns out, the DVSR will close if either of the two connected battery banks sees a charge voltage.
So here is my new house battery configuration. I had to put a plate across the oem depression to mount the larger battery box to.
That 30A ckt breaker feeds the new 12V buss I installed underneath the center console to feed the power to my retrofitted switch panel and the switches for the new devices.. I’ll cover that more in depth in another post but here are some pics.
I just re purposed the OEM switch panel that held the jet wash and cruise assist, I moved the jet wash to the left and put the cruise assist where the jet wash was. In my mind this will make it easier to use the cruise assist as well.
Here’s how the stock panel looks.
This was as far as I got last night.. I got the ckt breaker mounted for the trolling motor, as well as a Victron energy bluetooth shunt that will allow real time viewing of the trolling motor battery bank.
Yes, that area is a PITA to work in.
I’ll post back again after my first voyage of the season in a few days… if it all works out like I think it will, this will be a bit of a game changer, at least a tripling, if not quadrupling of the house battery power, and at least 250% increase in the trolling motor bank.
Special thanks to @mrcleanr6 @HangOutdoors and everyone else for their input.
Oh, almost forgot, got this from Minnkota yesterday.
Fantastic Job. Battle Born's are solid batteries and a good choice.
That is what I have. Works fantastic.Ha…after reading thread I’m glad I grabbed two Bass Pro lithiums along with the Minn Kota last month. Nice to know they are pretty good!
Nice! Glad to see you have all the details worked out. Its little things like the dsvr that you dont even think of when making this switch.
If I wasn’t needing the heated part for the batteries I would have gone the Tracker / ReLion route. ReLion has excellent customer service, one of only two companies who actually answer their phones, and it appears they stand behind their product! And since you are buying them at Bass Pro / Cabela’s if there is an issue you can just take it back to the store.
So a word of info for you and @Ericd, if you ever run those batteries all the way down to where the BMS disconnects the battery, just remove the positive or negative, or in the case of a trolling motor unplug it from the boat mounted plug and the BMS will reset itself.
Cliff note me - what is the best battery for the money?
I currently run 2 6v golf cart batteries for the stereo but want to cut the weight. My NOCO charger will support lithium. I currently have 210aH with the batteries. Also what is the minimum I could do for starting battery?
If your 210Ah / 2.51 KWh batteries are sla or lead acid your true ah / KWh is 50% of that at best, or 105Ah / 1.25 KWh. According to some independent testing I’ve see it’s more like 40% so 84Ah / 1 KWh.
Further if I read your post correctly you’ve got two 6V in series, when batteries are in series the Ah is not additive. The only time Ah are additive is if the batteries are in parallel.
If that is true then you only have 105Ah, 40% of that is 42Ah / .6 KWh
So with two LiFePO4 100Ah in parallel (62# total) and a depth of discharge of 80% you’re looking at 160 Ah / 2 KWh of energy. A significant increase, more than 300%. As well as a big weight reduction.
If you went with just one 100Ah LiFePO battery, 31# at 80% DOD, you’d have 80Ah / .97KWh. A 30% increase in power and a substantial reduction in weight.
If you don’t need the heated batteries like me I’d go with either Battle Born or ReLion (tracker branded at Bass Pro / Cabelas ) I’d give the nod to BB since they are made in Nevada with cells from China, every LiFePO battery out there uses China cells, and BB’s bms is better
Both of these companies have great customer support. Whereas companies like Dakota lithium take two days to get back to you via email, unless it sales then they’ll talk to you.
As far as starting goes ReLion has their 100Ah HP battery for a starting battery. These batteries are 12V only though, single use meaning you can’t parallel them.
Now, if you call BB and tell them what you want they may set you up with a start battery.
For my start battery I just put in an Interstate group 24 AGM that seems to work great.
Hope that helps!
