E-Series Bimini tower tubing diameter? <Flag or rod holder>
fraserjr
Fairfax, VA
@fraserjr Lets see some photos of your install and placement of those rod holders!
As soon as I get them in the mail they will be going in with pics included. Again these are the combo rod/cup holders. My plan is to put them in one of the two cup holders on the swim platform depending on where they fit. I took both out the other day and it looks like with the angle, I can get them in the upper cup holders even though I would prefer them in the lower.
After that I will likely get a few to go onto the tower. I am curious to see where @hobineros put his.
hobineros
Cutler Bay, Florida
hobineros
Cutler Bay, Florida
Same on other side, have to get some with rod in this evening.
I did ponder over the idea ... You can remove the mounting bracket from the ones I got -- There is a bolt to hold said bracket into the position you chose with the little teeth. I was considering tapping a hole into the squared up portions of the main tower supports and just bolting directly to the tower. Not a big fan of making holes thou... But that position would be ideal for fishing rods.
fraserjr
Fairfax, VA
Surprisingly the two rod/cup holders came today. So I immediately pulled the cover off the back to see if they would drop in. Unfortunately, the replacements are 3.5" wide while the existing holes are a little smaller than that. So I got out my rounded file and got to work. After a little bit I was able to get the new rod holder in on the right side (I didn't have time to do the other side). I was also happy that I was able to get them in the lower cup holder spots which is where I originally wanted them. I had to turn the rod holder angle in a little bit to have it seated correctly but overall I think it works well. I will say, these Amarine-made rod holder seem pretty well made and heavy. My only issue is how big the screws are and how close they are to the edge of the fiberglass. I am really worried about the fiberglass splitting when I try to screw them in. Also, the fiberglass is only about a 1/4" thick there, so not a lot holding the screws. I am thinking of trying to use some sort of backer on the underside to add some support.
Did the hose from the stock cup holder reach the bottom of the deeper rod/cup holder.....
These look really good....I would think that with carefully drilled holes the screws shouldn't split the gel coat.
fraserjr
Fairfax, VA
No the drain hose didn't reach but I shouldbe able to extend it so that it does. The only problem is that there will be a big dip in the tubbing and I am not sure how well it will drain at that point.
View attachment 52933View attachment 52934
@fraserjr Another great idea/mod from you! Those would also hold a grill leg.
hobineros
Cutler Bay, Florida
Gift from Father in law today, fits on the stock table perfect. A nexgrill. For 1/4 the cost of a boat grill. Psh!
fraserjr
Fairfax, VA
Anyone have a good idea on how to paint or make these black to match the tower? I really don't want to invest in a powder coating kit if I don't have to.
hobineros
Cutler Bay, Florida
Plastidip spray on paint stuff! My buddy did his entire honda civic in it... looked nice when he figured put how evenly layer it. I did all the badges on my truck...super easy stuff to use.
Best part is... if u dont like it... let it dry and it peels off like a condom... lmao
Coheeba
32408 Panama CIty Beach FL
I am working with a local welder and having two mounts made and then powder coated for my 16' flag pole. I want them modeled after "Kwik Tek FWT-1 Wakeboard Tower Flag Holder" but made to fit the tower. One will have the bottom closed to hold my 1" diameter flag pole and the other (top) will be open so flag pole will slide through for upper support.
hobineros
Cutler Bay, Florida
16 footer u say!?!? Are u planning on making a sailboat ;)
Do you guys have a recommendation for custom flag embroidery?
hobineros
Cutler Bay, Florida
I wonder if you could just get longer screws.
The brackets are actually the limiting factor.... the distance between the screws is 2"... I had thought the same thing. No dice.
hobineros
Cutler Bay, Florida
Been searching around -- Coolwaterproducts.com sells a rod holder - flag pole in 4' and 6' varieties. I looked around and this was shockingly the only website I could find. Been reviewed on other forums, sounds like a good product. Probably will order me a US Flag and a Dive Flag / Random flag later on next month 4 foot versions... Bimini / Bahama's Courtesy flags are also 4-9 $s at West Marine if you are curious / need one.
Bill D
Prairieville, LA
I have 2 of the flag holders from coolwater. They're great!:winkingthumbsup"
