- Raleigh, NC 27614
- 242X E-Series
Digging into the Audi specs, after market hitches are listing class 3 hitches with 770lb tongue weights and 7700 Trailer weight:
So what I've read elsewhere that Class 3 tops out at 500/5000 is wrong?
Nope...not weight distributing...Class III hitch. Oh well, nice and confusing. My Audi manual says 7700 lbs towing capacity...with tow kit installed (which I have)....so I'll trust Audi.They may be quoting max rating with WDH, hard to say from the specs there. I think a good rule of thumb for this is definitely check with your specific vehicle and hitch setup, and use your best judgement. I will agree that a 6500# trailer behind a half ton pickup is less likely to need a WDH than the same trailer behind a unibody SUV with struts in the rear.
In my experience a Q7 tows better than any 1/2 ton pickup I know of, due its own weight, chassis strength and low CG, and completely superb traction control. Add TDI torque and it is amazing.Nope...not weight distributing...Class III hitch. Oh well, nice and confusing. My Audi manual says 7700 lbs towing capacity...with tow kit installed (which I have)....so I'll trust Audi.
That said, Audi ratings are with the factory hitch - that stubby, massive, solid bar that is strait and does not work for our trailers as the ball sits few inches too low. So, there is that.
I know! I got sick of that.Just need the right hitch to get the ball at the correct height. Mine is about an inch low when I raise the suspension....I may just flip the hitch ball to the other side (but I think that might end up being an inch too high....I have 3 freakin hitches....I'll try with one!)
I’d look at the Anderson hitch. It uses chains instead of spring bars for weight distribution. You can lengthen or shorten the chains to fit around obstructions on the trailer. It will work on an A frame or Y frame trailer. And sway control is built into the trailer ball so it works if you have other trailers where you don’t need weight distribution.I agree on the hitch class discussion which I think is somewhat misplaced.
I would say you are correct about WDH except when it comes to boat trailers wherein WDHs do not generally work.
I could be wrong though, could you point out which WDH to use with my tow vehicle and Yamaha/Shoreland'r trailer?
I think I looked at those at some point, and between the coupler with the break actuator, the bow stop with the winch, the trailer jack, and the hinge for folding tongue it just was not working but I may need to look at this again. Would love that for some of the long trips we plan this summer.I’d look at the Anderson hitch. It uses chains instead of spring bars for weight distribution. You can lengthen or shorten the chains to fit around obstructions on the trailer. It will work on an A frame or Y frame trailer. And sway control is built into the trailer ball so it works if you have other trailers where you don’t need weight distribution.
And you can back up around tight turns without having to disconnect anything.
That is the best system I've seen to date. It's remarkably simple, distributes the weight well, and will give you free reign to back at severe angles.I’d look at the Anderson hitch. It uses chains instead of spring bars for weight distribution. You can lengthen or shorten the chains to fit around obstructions on the trailer. It will work on an A frame or Y frame trailer. And sway control is built into the trailer ball so it works if you have other trailers where you don’t need weight distribution.
That's a negative, though close. I'm not sure when Yamaha stopped publishing the 'dry weight on trailer' specifications, but in 2017 the 242 LTD-S had a dry weight on trailer of 5,063lbs, which is no batteries, no fuel, no water, nothing on-board storage wise, etc. Considering the fact that nobody is towing around empty boats, most of us are sitting around 5500lbs even in barebones configuration (batteries, fuel, anchor, some PFDs, six pack of beer).
I got this also and I see that my tongue weight is a little less than 500 pounds, however I did replace my class III with a Curt class IV that has a 1000 pound tongue weight rating. I also added Firestone air bags for a perfectly adjustable trailer/tow vehicle level ride. Main goal was to get that "peace of mind" and only enjoy our adventures. Thanks for your inputs and advice.I know! I got sick of that.
I replaced this:
With this:
Not looking back.
where's this spreadsheet? I must be overlooking it.Actually according to the FAQ spreadsheets on the site here, up through 2016, the heaviest rig was the 242X E Series at 4914 wet weight including trailer. That's a full tank of fuel at 304lbs and trailer at 1241lbs.. I'm guessing you may be right that the 2017+ models may be heavier as our spreadsheets are not updated to those models.
Check out the FAQ for that info. It's good to know as it shows Dry weight of boat, trailer and wet weight.
The issues I see with the photos above of the broken hitch are two fold. That could have happened from too much tongue weight possibly more than weight of the load. And the fact that it shows a severe twist. There is more to that story. And what is with the bolt on receiver? Was it really that ghetto on GM"s side back int 2008? I had a Colorado back then, so I think mine may have been. But it was a mid sized truck. I do know the tongue weight was much less than a full size.
This why I ask, seems like most of us are using passenger vehicles that are only rated up to 5000 pounds. Wanted to know how critical those few extra pounds were.
@haknslash do you have more info on that last bit? I have an ‘08 Tahoe.
