Zackdadams
- MS Gulf Coast
- FSH Sport
Here is a detailed walkhrough of the Radar installation on my FSH 252.
After recently being caught off guard by a severe storm while offshore, i've decided it's time to get a radar.
In case you are wondering, the boat now has 142" (11' 8") clearance on the trailer with the Radar Dome installed.
Part 1: The Radar Dome
The Simrad unit we have on our boat is the GO12 XSE.
According to Simrad, this is compatible with the Halo 20 and 20+ Radar domes.
I've decided to go with the Halo 20+, because of longer range, among other bells and whistles.
www.simrad-yachting.com
I purchased mine from Hodges Marine.
www.hodgesmarine.com
One of the biggest decisions about mounting your radar is how high it needs to be, and the angle.
Here is a great YouTube video from Simrad about mounting heights, setup, etc.
I'll be installing Simrad's recommended mount, the Scanstrut 6" PT2004.
There are other options, as well as angle wedges, but I believe this will be fine for my setup.
I also purchased this from Hodges Marine.
Step 1: Mounting Radar to Scanstrut
The first thing to do is layout the template Simrad provides, on the Scanstrut.
I measured the mount, and drew accurate lines to find the center.
I centered up the template, and taped it down once I found the best location.
I then drilled 4x 3/8" holes per Simrad's instructions.
Note: The Scanstrut is fiberglass, so I ran my drill bit in reverse so as not to crack it.
I did have to end up hogging out the holes a little for the bolts to fit properly.
Afterwards, I flipped the dome upside down, installed the cable, and set the Scanstrut on top.
I coated each bolt with Loctite, and installed them.
Step 2: Mounting Radar to Boat
The next step is to choose a location on your T-Top roof.
I set the Radar on my roof, to get a feel for where it would work best.
I unscrewed the black plastic above the window, and using a bungie cord, hung my VHF equipment, so I wouldn't have to disconnect it.
I then pulled a tape measure from the rear of the T-Top to the inside of the opening, to see how far forward the radar could be mounted.
In my case, it was 60" from back of the T-Top towards the bow.
To find the center of the roof, I pulled a tape from the rod holder openings in the T-Top.
In my case it was 20-5/8" to the center from the rod holder opening.
I drew pencil lines to mark the center, and also marked the center of the Scanstrut.
(My anchor light was in the way, so I had to remove it.)
Once I liked the position, I marked and drilled 4x 3/8" holes in the roof.
Afterwards I drilled a 1/2" hole in the center for the cabling.
Next I ran the radar cabling through the Scanstrut.
The mount includes some cable glands, but I decided to use my own.
I linked to them on my VHF Radio installation.
The T-Top roof is only around 1/4" thick, so you'll need to install a backer material of some sort.
I had a nice piece of cedar that I used.
I had my helper hold the backer from below, while I marked all the holes from above.
Afterwards, we installed the bolts, nuts, and washers, using Loctite once again.
And it's mounted! Now on to wiring!
HALO20+ Radar | Simrad USA
Pulse compression radar with 20-inch dome antenna, 36nm range, 60 RPM operation and VelocityTrack.
Simrad Halo20+ 20" Radar Dome W/10m Cable
SIMRAD HALO20 20 RADAR DOME WITH 10M CABLEHALO20 20 Radar with 10M CableSee Far And Near With One Compact DomePerfect for a wide midsized to large sailboats, HALO20 comes in a compact 20inch dome antenna and delivers highquality short, mid an...
Scanstrut 6" Powertower For BR24 Dome | Radar | Simrad USA
The Scanstrut 6" Powertower For BR24 Dome. Find more industry leading Marine Radars and electronics here. Buy Online.
Search results for: 'scnpt2004 scanstrut powertower 6quot powertowerreg compo'
