- North Caldwell, NJ
I think the side force stabilizer used in the Ultimates could be making a difference. But I could be wrong.This may have been covered before but the it is obvious that the TV's and the Ultimates, et all are going to generate some level of spray / misting when they are operating in the "kick-up" mode. The vane or wing that catches in the jet stream is held up by the higher pressure water on the bottom and lower pressure on the top which will create a spray and pressure vortex similar to the wing of an airplane - reason for winglets.
