Mystic1906
- Lockhart, FL 32810
I am of the serious opinion that my boat hates me. Pulled it out of storage today to do a last minute check before taking it to the dealer tomorrow for a trade check. Pulled the battery off to check the charge, reconnected it and then tried to start the engines. Starboard engine started fine with no issues but the port engine wont even turn over. Nothing, not even a click, when I turn the key.
The stereo doesn't turn on either but I don't know if it's related. My last trip out everything worked fine so I am at a loss.
So here are the steps that I took to troubleshoot -
1) I switched out the ignition switches to see if it was a bad switch. No joy with the switch that worked on the starboard engine.
2) I tightened the nuts on the battery to make sure there wasn't a loose connection. I also removed all the cables and reconnected them but no joy from that either.
3) I checked the fuse that was attached to the positive wires between the battery and the engine.
4) I opened the engine hatch and pulled every fuse in the round fuse holder on the port engine side. None of the fuses were bad.
I am at a loss as to what to do/check next. HELP!!!!!!
@Bruce @Julian @Andy S @Mainah
Just tagging as many people as I can for your expert advice. I want to resolve this before I take it to the dealer tomorrow if at all possible.
