@Cobra Jet Steering LLC do you use the rack to push the weeds forwards off the intake? Just trying to ensure @Sugarsand gary has the right approach and technique. How about a Cobrajetrake?
I recall seeing a pic of a small rake / claw about 6" wide with 4 to 6 tines mounted to a metal handle shaped like a "J" and thought it was supposed to be used from the back of the boat or Pwc to pull debris from the back and down starting at the front of the intake grate. Use would have been by feel not sight so practice on the trailer or on the water could not hurt.
@Sugarsand gary , Jeff is the founder/owner / operator of a a company that makes cobra jet fins (which enhance steering responsiveness of pwcs and jet boats). So the reference above was a joking suggestion that Jeff produce a grate rake as well.
The only thing I miss ie 5he Jersey shore lots of good Times.I love going to see the b street band.thurs nights at the deck at the golden nuggets.we also have a timeshare in ac we can't sell.
Nugget deck is great...I always pull up there... Also good luck with that ac timeshare...that place has gone down hill real fast, hell all the luxory condos directly next to revel have gone up for auction with NO minimum bid
Seriously if you get the reverse trick down correctly it should solve most of you issues, and be sure to get the weeds out before they choke off your cooling system.
I just came home from the water and it was weeds galore as usual, do your best to drive around them with your new steering it should not be that difficult. I had to do the reverse caper on my ski today, didn't see the weeds and slap ran into a big collection of them, couldn't find a wake to jump to knock them out of the intake , so I did the reverse maneuver and sure enough the weeds " sea grass" came floating out the back.
