- Raleigh, NC 27614
- 242X E-Series
OK, I completed this job today, and it took WAY longer than it should have due to some unforseen challenges and that I'm anal and like to go slow. I began at 10:15 (boat covered) and finished at 3:30 (boat covered).
The cables I ordered were TELEFLEX CCX 63317 or TELEFLEX CC63317 for my 2005 (same part#--the one with the X is the latest version of the cable). I bought them from iboats.com for $44 each. Search for "3300 xtreme control cable", then chose the 17' version and you'll see this part number appear...their search doesn't find the part number! Here is a direct link (buy it from the vendor with the best price plus shipping--which for me was iboats--shipping was FAST TOO):
http://www.iboats.com/3300-Xtreme-Control-Cable-17-Teleflex-Marine/dm/cart_id.980701067--session_id.912360446--view_id.169426
I used the service manual Hull and Deck schematics for my 2005.
I'm used GVANs step by step and enhanced it with photos....See the photos with directions here:
https://www.facebook.com/photo.php?fbid=10200509625414855&set=a.10200509624694837.1073741826.1584386227&type=3&theater
1 Buy the TELEFLEX CC63317 cable, not the Yamaha OEM F1C-U149C-01-00 cable to save $$. (iboats had it on sale for $38 while my local Yamaha dealer wanted 149.99 for the OEM cable)
2 Remove the 4 screws from the plastic binnacle cover, then remove the cover (mine was a PITA to get off--there are 4 little pins in each corner that hold it on).
You can just see the pins in this shot..the left pin is off, the right pin is still holding the cover down....
Then remove the 4 screws holding the binnacle in place. The shift binnacle housing did not come out easily after removing the screws. Be patient and wiggle it out.
3 Remove the three long screws that hold the two binnacle housings together. (this was where I had a 1-1.5 hour ordeal as someone before me had sheared off a screwdriver tip in one of these screws--I was able to rotate the two binnacle to loosen it up--took me a while to think of this--This pissed me off so much I stopped taking photos...so the next bit has no photos! Sorry)
They are two separate housings.
Remove the two screws holding the plastic cover plate on. Pry off the E-clip that retains the shift cable (the shift cable is the marked with "A" on the photo below), so the shift cable is free to remove. The slide the throttle cable out from the bottom ("B" in the photo), followed by the plastic spacer. Don’t lose the spacer in between the shift and throttle cables as these cables enter the binnacle housing. Then remove the shift cable.
3a. Loosen the nut holding the connector on the end of the cable, then unscrew the connector (count the number of rotations it takes to remove the connector - and put it on the new cable with the same number of rotations)
Now I have a 2005, so accessing the space between the under seat section and the bilge area is easier as I have a storage hatch and access plate. So I fed the cable from the under seat section, forward to the binnacle hole easily, then fed the new cable back to the bilge are easily also. I did need my wife to grab the cable through the clean out hatch tray. In hind sight it is probably easier to fish it from the stern all the way forward....but this worked ok for me.
4 Need to remove the bilge hatch cover where the cleanout cans are. There are a bunch of screws. To get the cover / hatch out of the way, I had to disconnect the drain hose clamp once all screw are removed
5 I pulled rear of the old cable into the inside of the hull / bilge area prior feeding the cable from the front. You will need to cut some zip ties to get the old cable out. So be sure you have some new ones to secure the new cable.
6 GVAN's directions say "Thanks for emphasizing that the cable ends (front / rear) are indeed different and I avoided feeding the new cable through backwards thanks to you." THIS COMMENT BAFFLED ME...I CAN SEE NO DIFFERENCE in the cable ends. I think older model boats might have had different cable ends. I've been asked about this later in the thread and by private message by other members-I saw no difference, and neither did they!
This is how GVAN did it....I didn't join the cables and just fished it on its own.
7 To connect the old cable to the new one to feed it from the shift area to the stern, I put a 3 inch small hose over two cable ends including the small nuts on each end (old and new). Then I used small tie wraps to tighten the small hose so the cables would stay connected. Then I used electric tape to cover the hose and tie wraps where the old/new cables connected to prevent snags while feeding the cable. I had my wife push/feed while I pulled. No problems. If it gets snagged, wiggle it while pulling/pushing but don’t force it…you don’t want the cables to come apart.
7a Undo the reverse gate--this is tricky if you don't know how the clip works. It is spring loaded and takes a thumb nail or a screw driver to get it squeezed together (see the photos).
Once you have the gate disconnected, remove the connector (count the rotations to get it off), then the nut, then the boots, plastic hull cover, washer and white plastic clip (that looks like a white plastic washer but is actually a clip-see the photo below) and push the old cable into the boat.
7b thread the new cable out, and re-assemble (see the photo). Again, put the connector on with the same number of rotations.
8 You need to put silicon on the inside of the hull where the cable comes through the hull.
9 Then re-assemble the boat (clean out tray back in --that is so much fun)
There are more photos in the Facebook album and more comments on the photos as well. Overall, this wasn't that hard--I'm sure fishing the cable in the 2007+ models or the 210s would be harder and will require taping the old and new ones together. Hope this helps someone! I prefer pics!
