- Rosebud, Mo
- 242X E-Series
Ouch. Gotta hand it to ya, takes a big man to fess up. I'd have blamed the wifey. But really, as long as the fiberglass isn't compromised you can get a kit from West Marine http://www.westmarine.com/gelcoat-repair-kits/west-marine--gelcoat-white-quart--12953881 or any online marine seller and cover that. It doesn't have to be real neat as you'll be covering it with the keel guard. You just want to make sure that you keep the fiberglass absolutely dry by sealing it before you cover it. I had a similar but smaller issue that I fixed this way before installing the keel guard. Out of sight is not out of mind.I guess over the few times that we went out and beaching it. Might of hit a big rock buried in the sand. It wasn't there when we bought the boat I checked out the hull very well.
I will let the experts chime in here but from everything I have read you do not want to allow water or moisture to get to that unsealed fiberglass. I recommend gel coat or marine Tex, which is easier to work with before putting on the keel guard.I'm going to just cover it. I checked and the width of the Keel Guard will cover it. The actual damage is pretty minor.....just really ugly!
I put a keel guard on my XR and it saved my boat when I hit a pointed rock under the water line,so I know the full value of the guard. I also know the excellent customer service they have. Called them up and had a replacement 2 days later!!I have a 14 foot strip. You won't regret it.
I am going to get my gel coat repair done and let that cure for awhile. It isn't going to be extremely warm out so I want to make sure that I get that done first. Then I want the weather to be a little warmer out before I put on the keel guard. The near 80 degree days were fine but it doesn't look like we are going to get those for awhile again. I can let you know when I do it though @mattschepker . Like wise in return and we can always heat your garage up more, I can bring over my torpedo heater.when are you going to put your keel guard on? Do you want some help
