Inline Fuses
HangOutdoors
Royal Oak, MI
I have seen several differrent parts that are for inline fuses. I need a 1, 2, 10 amp ones.
Any recommendations of which types are good especially in a Marine environment?
I would install a fuse block...that way you'll have more spots for anything you want to add in the future. Makes wiring easy.
Something like this would be perfect for you:
I've bought blue sea ones in the past as they were the most available....but there really is nothing to these things....so I'd consider a no name in the future.
Sonic Blue
Ontario Canada
252SD
this thread got me researching a little. I hope to be working on some new electronics in the coming weeks. I have a marine fuse block as recommended by @Julian (and I thought I read that @HangOutdoors had one already) ... but anyway, I found these fuses onlin at a local car parts website. The fuse lights up when it blows. I like that feature especially where I plan to mount my fuse block. Instant trouble shooting. F6C5EBE2-C9B8-4F00-A4F7-D2AD7A8934D5.jpeg
HangOutdoors
Royal Oak, MI
@Julian I was considering doing another fuse block but figured it may be overkill. The wires in question where the 10 amp negative fuse that the Blue Seas ACR requires and the other 2 amp one was the Aux from the Trim Tabs require for the ignition tie in. Probably should of clarified this in original post.
One in the battery area and one under the helm. I figured for just the two right now it wouldn't make sense to put another fuse block in the battery area and another under the helm and use inline. Although, the I was contemplating the 3 inline ones that Yamaha puts in stock and I could cut those loose and put them all in a fuse block. Running short on space though.
I am using fuse blocks for everything else in the battery and helm area which are powered.
I ended up going inline ATC 14 AWG holders that I got at the local hardware store.
@Sonic Blue I have two fuse blocks but they have Positive and Negative terminals and wouldn't work in the scenario for these two wires. The fuse block @Julian linked would work but I would have only one wire on each.
zipper
Boston Whaler
For that many circuits I would agree with @Julian. Find a 6-pos. +/- fuse panel, I used BlueSea. Feed from the battery thru an in line circuit breaker and wiring to/from the panel rated for the inline breaker. And then you will have a few extra places to connect accessories in the future.
HangOutdoors
Royal Oak, MI
@zipper That type of fuse block wouldn't work with the specific two wires I was looking to fuse see above post. As for feeding the Fuse block that I put in for power under the helm I have a 60 amp inline resettable circuit breaker between the fuse block and buss see the center lower breaker. That runs to the helm with 8 AWG Duplex Marine. In the Pic, you can also see my second fuse block which will handle things on the port side and some mods in the engine bay.
HangOutdoors
Royal Oak, MI
this thread got me researching a little. I hope to be working on some new electronics in the coming weeks. I have a marine fuse block as recommended by @Julian (and I thought I read that @HangOutdoors had one already) ... but anyway, I found these fuses onlin at a local car parts website. The fuse lights up when it blows. I like that feature especially where I plan to mount my fuse block. Instant trouble shooting. View attachment 148258
I am no expert and learning, but would you really want an ATO vs ATC in a Marine Environment? I think exposure to the elements wouldn't be a good thing.
Sonic Blue
Ontario Canada
252SD
Hmmmm. I just assumed that’s what you put in them. I‘ll research again... I didn’t know there was a difference or a separate “ marine” fuse for those blocks.
HangOutdoors
Royal Oak, MI
It's really not a Marine fuse per say. ATO is open at the bottom where moisture and the elements can get in. ATC is closed so the full fuse is sealed. They both fit in the same slot. How important that is I am unsure in real world tests, but I went with the sealed for piece of mind.
Not that I knew much about fuses, but the guy at the hardware store gave me an unsolicited 30 minute lesson on fuses yesterday when I rolled up in there looking for the inline ATC one. At least I have talking points for my next social event. :)
RobbieO
Sacramento River Delta
212SE
Beachbummer
Houston TX
Last time I make the pitch on this thread...
12v breakers are a thing, as low as 3 amps, there are even smaller if needed.
When you blow it, just push the button. Unlimited resets. With the fuse, it blows and you are out of luck unless you have a replacement. humble selfless pitch for a product I find really really useful.
HangOutdoors
Royal Oak, MI
ChrisM
Rock HIll, SC 29730
Chaparral
VR
Umm,,,,,see post #3...?
I don't know anything about how Yamaha does their electrical, but on my Chap, there isn't one "fuse" present, all re-settable breakers.
