We are in the same boat - no pun intended.
A couple weeks ago we purchased a 2017 AR210 that was still brand new with full warranty. This is our first ever boat. Like others said, it makes for good family isolation time during the COVID. From what I hear, boat sales in Alberta, Canada are up big time too now.
Sure glad I found my way to this forum and a big thank you to everyone for sharing your expertise and knowledge.
As we approached the boat ramp, returning from our first ride on the water, I had my son open the floor locker to grab the boat fenders. Much to my surprise the locker was 3/4 full of water. I later realized all the compartment carpets under the seats were damp also. Searching this forum, I discovered that the problem was the drain tube in the anchor locker. I plugged the gaps in the drain hole with silicon, and successfully addressed this issue.
A couple things I have wondered about:
- Jet Pilot Thrust vectors or the Cobra jet steering systems. Are they worth it? which set-up is better? Based on my first few drives around the docks, some added low speed control would be beneficial.
- I often wonder what basic gear or tools I should have on the water? Simple things to help a person out in a pinch with more typical or likely boat issues.
- What other peoples favorite accessories or modifications are?
- It appears lots of people on this forum are running in salt water. I wonder, in lake water applications, is flushing the motors and pulling the port plugs on the regular as important?
Thanks again Jet Boaters Forum.
Woodsy
