drewkaree
- Central WI
Late to this thread, but glad to hear you went with the 210. Direct from Yamaha's website, the dry weight of a 2022 AR210 is 3228 lbs. I would have no reservations whatsoever towing a 210 with your V6 Tundra, as, IMO, it's not close to the lowest V6 rating I saw (4500 lbs).
Some observations from my Lexus GX470 (glorified 4Runner) - although mine is a V8, it still has some things that might be helpful to you: Premium fuel helps tow better. Nothing to do with how it trailers, it simply shifts less than it does with regular. I CAN run regular in my GX, and I do over winter, but when boat season comes, I head to Costco for premium. Also, I think your Tundra might have a tow setting/button, or overdrive. It will tow better without the overdrive. Take the boat out for some testing and see what settings work best for less shifting or more power when going up hills, for instance. This means ANY hill - even some slight inclines which I wouldn't consider a "hill" made a noticeable difference.
Get an adjustable hitch, OR wait until your pick up date to measure the drop between the trailer and the truck, and make a quick run to your local WalMart and get a hitch with the drop you want. Alternatively, buy several hitches with different drops, and take them all with you on the day of pickup, and return the hitches you won't be using.
Find a scale in your area, or get a tongue weight app, or buy the tongue weight scale. Find the thread around here that refers to what you're looking for the tongue weight to measure in at (some research on your part there). On the day of pickup, have the dealership help you set that tongue weight before you take off down the road. With you having a V6, I'd say it'll be more important for your towing comfort than with a bigger truck with more grunt, but no matter what, it's better to get that set before you sign off on it and head off down the road. Shouldn't take more than half an hour of time, but with the dealership assisting, realistically it could be done in 15 minutes or less.
If you're mechanically inclined, look at the oil change threads, and use any discount the dealership gives you to pick up those tools you're going to need (oil sucker, filter removal tool) as well as filters/oil change kit.
Buy stuff NOW for your boat. Even if something happens, and you end up with some other boat, you can always use the following items with any boat, and you're going to have a lot you'll want to add when you get it - buying necessities NOW will help you avoid skimping on them later when your wallet will be far more stretched when you're thinking about that first payment as well. Get at least one anchor, along with lines for it. Buying it now will likely save you money over buying it from the dealership. My thought was that the Yamaha anchor would be a pain in the ass, and there were mixed reviews on its holding power. I went with two Mantus anchors. There's a member on here who sells them, see if they can hook you up. Likewise, get yourself at least 3 fenders and lines for them - same reason, save money over buying from the dealership. My experience was that the dealership also WOEFULLY undersized the "stock" fenders they would supply me, although I could get larger fenders for an additional cost. That additional cost ended up being ridiculous. Many types to choose from. I got 8" Taylor Made's like these I'm linking to. You can find less expensive versions as well. My dealership was going to provide, "free of charge"
, 4" fenders, and if I wanted to move up to 8", I essentially would have been paying close to full freight for the 8". GET LONGER FENDER LINES THAN YOU THINK YOU'LL NEED. I have seen it OFTEN with friends who have gotten new boats, they're given "free" fender lines that are 5' long by their lovely dealerships, only to find that 5' fender lines turn out to be as useful as tits on a bull when it comes time to tie up to the pilings around here, and they're praying the knots they have to tie on the bitter ends won't come undone. They soon buy new lines.
Look at the other threads around here for AR210's, and look for the issues they have. If you're up for it, have the dealership fix these things BEFORE you pick up the boat, but realize that may delay your delivery. You may consider doing the simple fixes yourself. @HangOutdoors , myself, and multiple other guys have 210's, and the anchor locker drain may have been addressed in your model year, but if not, fix it yourself or have them do it before pickup. Same with any other leakage issue, like the cleanout tray and hatch. Not trying to put you off your boat or make you question yourself - you're getting a great boat for your family, these are just things to look at. They may have fixed/addressed all of these things with your model year, but there's no way for you to know without knowing beforehand what MIGHT be a potential issue for you to look at.
I don't know if SeaDek was an option for your boat. If it was, and you were hesitating because of the additional cost, call them up and tell them you changed your mind (or decided) to go with the SeaDek. Look around here, NOBODY was glad they bought their boat without it - it's one of the mods that seems to unanimously be agreed upon that "man, I wish I had done this right from the start!".
Anyway, stop reading threads where they talk about add-ons or additional stuff to buy. We're great at doubling the cost of your initial purchase, since it's not our money! ???
I very much enjoy my boat, and I'm glad I was able to take the step up to the 210. I was initially going to be going with a 19', and most likely, I would either already have a 21', or would be looking for a deal on a 21'. Like many here, it took a bit to get it to the point I'm at now, but I wouldn't trade the experience for the world. I'd consider a used 24' boat now, but I'll be perfectly fine with my boat if that perfect deal never materializes for me. Good to have you here, hope you enjoy the experience!
