- Corinth, TX (DFW)
you should pinch at "C",
if you are unsure of how good you clamp is you may want to remove the hose at the engine side of "C" also but monitor for any water coming in,
you may also want to run with that engine the throttle in full forward to help prevent water pressure build from the bucket being down on over the jet in the neutral or reverse position
I wouldn't swap the good fuse either until you are at the dock at least,
