Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
I have the same one and intended to use it on the boat but instead it has become our main grill since our home grill died. I like this grill as it's very easy to use, seems to always light right up, and cooks the food evenly. I have yet to try it in the boat which is what it was originally intended for. Glad to here it works well. I have a habit of burning off the crud before and after I cook and this melted the plastic lock mechanism on the front. I contacted Cuisinart about it and they sent me a new part. They said it shouldn't be run at high with nothing in it otherwise that will continue to happen. Seems like that plastic part should have been something other than plastic.
I carry a Coleman grill like the one in @Ronnie 's photo but I don't have it mounted. It's flat and stable on the table but I usually just have it sitting on the swim platform while I stand in the water flipping burgers and brats.
@farrelltravis has the same one with a mount that works with the standard table pole so it basically mount in place of the tabletop maybe he can share a pic and more details on the mount
This is my current set up when I'm out on the river. But I definitely need to do something to get some hot food goin while I'm on the lakes in SE Wisconsin.
Cooked up some prime top sirloin courtesy of Sams club. It was done perfectly to 125 degrees with beautiful sear marks thanks to the cast iron grates on the Weber Q. Instant garlic mashed potatoes as well. Mmmmm.. The dog wouldn't take his eyes off the grill!
I am just wondering if any of the main contributors in this thread are still monitoring it. Most of you Texas guys know I have been grill resistant and just gone with my foil/towel/cooler method of hot food transport and boating. Well, we are adding a grill to be able to use it on the motorhome and want to be able to use it on the boat if I so desire. I had it narrowed down to the Weber Q 1200, but it won't work for several reasons, although @steined may argue the point. They tell me it can't go on a table like it is being used, that it is too hot for that. But the actual reason I called them was about hooking to my propane accessory line on the coach...they say I can't do that either with that grill. There is a burner tube and if you remove the regulator that just sticks into that tube, you have no way of hooking any hose coupling to the Q. So it got X'ed off today. We have looked at everything from Charbroil, Coleman, and a slew of others, and the Magma is certainly the easiest to adapt to the coach, and to the boat. The model I am looking at is the Adventurer "Cabo" Model A10-703. It has folding legs so it stores easily and can be used stand alone on the ground, on a table, or on the boat with the T10-327 that @Bruce has, or the pole mount that @davel501 displayed from Yamaha. I am looking for a table that folds or some kind of stand for it and a prep surface for the coach. Ideas?
added...I see the Kuuma is also getting some good marks. My concern is that any grill designed for high pressure LPG, may not work on the coach with a standard bulk tank and hose fitting, just like the Q. Any knowledge any of you have will be helpful!
For the Weber Q, I've cooked all sorts of steaks, burgers, etc and never had any issues with the heat under the grill. The legs are even plastic so I can't see the table being an issue.
As for the connection between the RV and the grill,
Basically you remove the existing weber regulator, install a quick disconnect fitting in its place.
Get a hose that goes from RV port to new quick disconnect on the grill. RV Done
Get a quick disconnect for the removed regulator and install it on the regulator. Now when you want to use a 1lb bottle, you just attach that regulator to the quick disconnect. Portable/Boat Done.
My father in law was asking me about this the other day actually for his RV.
@steined , thanks for the insight! I am not sure it is that easy however. I get the liability issues that Weber wants to avoid. They have my name/address/phone/grill model dating back to 1995. So my question of hooking up to a low pressure source like a bulk supply tank, such as my big tank in my yard, or my 38 gallon tank on the bus, should have been easy, as that is how my Genesis 2000 is hooked up. She said now, even the larger models have a secondary regulator that must be changed, and that any change by anyone other than their approved service outlets would void a warranty. Now the Q warranty is of no concern, but she also told me that the burner tube coming out of the Q wasn't threaded to hold anything except the valve that is on it, and that removing it would just leave an open tube and nothing would hook up to it. Maybe I should go disassemble one and see, or do you know for certain that an adapter would actually screw into it? I am just going on what Weber told me yesterday, and no first hand experience with the Q.
