Beachbummer
- Houston TX
- SX
Yes, that's how it works. You are only replacing the bottom of the plug. Video will help.
I know it sounds like a lot, but I myself coming from the inboard/ outboard market. I always have had plenty of things to do to the boat. I was very skeptical of the lack of maintenance on these boats, I always thought I am missing something. Now I have to find things to do and often they are not boat related. There really is not a lot to do. Rebuild your plugs, install the ez locks, and enjoy.I agree. I don't want to put my family and/or friends in any kind of danger. Like I said in a previous post, I wish the sales person would have educated me a little more, but he might have been afraid of scaring me away lol. I am going to go ahead and do the replacement kit too. I bought this boat used. Since the other owner bought it new in 2009 and only put 88 hours on it in all that time, it set in dry storage forever. That is good in some ways, not so good in others. By replacing the bottom part of the plug, installing the ez lock, spraying lubricant and taking them out between uses hopefully I will be able to enjoy this boat now. (All things I learned on this forum today!) thanks all
Good info on not leaving the T handles unlocked, Jeff. I always leave my plugs out when not in use, and religiously spray silicon on them, but this is the first I have heard about the T handles....thanks again!So that is a double edged sword if you remove your clean out plugs from the holes while you store them DO NOT leave the T handles in the UP position , rather push them to the locked position , for 2 reasons, the small spring that operates the tray will be extended not compressed , compressing the spring weakens it secondly the plug gets water sand etc. inside it .
If you allow the contaminated water to evaporate while the tray is in the unlocked position you are allowing the particles to be left in the track forward of the tray and this is one reason the trays do not go all the way forward to lock properly.
When you realize the cleanout plug is just forward of the pump and the bottom of the plug is also the bottom of your boat,
to make that worse it is in the intake tunnel so hitting waves puts a huge amount of force on the bottom of the plug , this is the force that knocks the plug loose and often blows the rear hatch open etc. These plugs are in all Yamaha jet boats from the year 2000 to the recent change to the twist in plugs .
Let us know how the plug maintenance goes and if that solves your problem....and enjoy many years of boating!OK I see now. Thanks to everyone on this today! I am sure as a newbie I will be back with more dumb questions!
