Ronald
- branson mo
- Limited S
So whats the latest and greatest to lube the clean out plugs..2014 242 ls
Julian, is there anything special that needs to be done to 2017+ Cleanout plugs maintenance wise?This is what Yamaha says on the subject (does not apply to the new twist in caps from 2017+):
I would say the primary thing you want to do is the same as the older ones....rinse them with fresh water after each use (use saltaway if in salt water) and leave them out to dry. Leaving them locked in for prolonged periods will only risk them getting stuck with mineral/salt deposits. Cleaning them periodically would be a good idea as well, especially the parts that engaged in the locking mechanism.Julian, is there anything special that needs to be done to 2017+ Cleanout plugs maintenance wise?
