Cambo
- Long Island
- 242X E-Series
Eq's are a great addition to these boat systems I had one on my 2005 with multi amp system It was a was not expensive and worked great for balancing out the sound and allowing fine tuning. The new system is in phase 1 My goal was to have total control of volume tone and crossover points so I took the front and rear RCA connections from the Polk PA4A and fed them to two separate EQ's one would be good for most systems but they are inexpensive . I did use the wet sounds 420 but the American base works just as well for a fraction of the price and has a built in volt meter , it doesn't have the PA. This was needed due to the poor cross over on the Rockville amp.
