upperdeck
- menomonee falls, WI
- X
I couldn't dig up my photos, and my boat is in storage. But here's what I did.
I used this antenna.
http://www.amazon.com/Shakespeare-5242-A-Profile-End-Fed-Antenna/dp/B00JDI0M44/ref=sr_1_3?ie=UTF8&qid=1397868111&sr=8-3&keywords=Shakespeare 5242
You can see it comes with a 90° bracket. I mounted the vertical part of the bracket on the vertical part of the tower where the support attaches. See arrow below. I attached it by drilling and tapping this block of aluminum.
I then ran the antenna up the tower and made the connections. Pretty simple install.
If you really need the range, go with an 8' fiberglass version. I chose this compromise because the whip is easily removed for storage. The cannister on the bottom and the wiring remains installed.
