are those sealed on the bottom, and if not how did you run drainage from themI got some new fishing rods and needed to expand my rod holder count beyond the 3 tower mounted ones, so I decided to go with a couple of flush mounts. I think these will be good if I decide to do any trolling etc., and can also use them for grills or other toys. The fiberglass is surprisingly thick back there. I wasn't expecting that, but they are nice and sturdy. It's probably close to 3/4". One weird thing happened during the install. I was squeezing silicone out around the opening and screw holes and the tube blew out the back. That was a huge mess, but luckily the silicone job was done. Overall, it was an easy install and I'm glad I did it. I'll test them out this weekend when I go pike and walleye fishing Saturday.
View attachment 56485 View attachment 56486 View attachment 56487 View attachment 56488
No, they are open on the bottom with just a rail across to stop the rod handle. They have rubber caps that are water tight so I didn't run drainage.are those sealed on the bottom, and if not how did you run drainage from them
Mine are in an nearly identical location. I think mine are 30 degree and 15 would likely be better.I got some new fishing rods and needed to expand my rod holder count beyond the 3 tower mounted ones, so I decided to go with a couple of flush mounts. I think these will be good if I decide to do any trolling etc., and can also use them for grills or other toys. The fiberglass is surprisingly thick back there. I wasn't expecting that, but they are nice and sturdy. It's probably close to 3/4". One weird thing happened during the install. I was squeezing silicone out around the opening and screw holes and the tube blew out the back. That was a huge mess, but luckily the silicone job was done. Overall, it was an easy install and I'm glad I did it. I'll test them out this weekend when I go pike and walleye fishing Saturday.
Thanks! I must have checked 15 times that no wires or anything would get hit.Nice install @Rainmakr. I haven't had the balls to drill thru the glass yet to put in any flush mounts! Gotta let the new wear off first.
Andy did you need to do any modification to get it to fit suggly there on the back rail?I believe so. If I’m not mistaken the tube size for the tower is 1 7/8” which is the same as the AR240 you saw with these mounts in earlier pictures. The Dolphin rod holder works for 1 1/5” - 2” per the Amazon description.
I didn’t use the Dolphin holders. I have an e-series and the tubes are bigger than the AR240 so I had to go with a different brand. @robert843 had these on his boat and may be able to shed some light.Andy did you need to do any modification to get it to fit suggly there on the back rail?
I used the same as @Julian but went with the 15 degree instead. I kept the rubber gasket on them to help hide the fact that the gunnel wasn't completely flat where I mounted them. I got two on the bimini frame as well for when we're not using them to keep them out of the way and use these to hold the rods when we're chilling on the back deck fishing and drinking beer.
View attachment 64711 View attachment 64712 View attachment 64713 View attachment 64714
do you think 30 degrees would have been better for trolling? Thanks
