- Royal, AR
- SX
There is a video posted on winterizing and they guys there pointed out that the bilge pump cycles every 2 minutes. Is that accurate? If so, that seems like a long time between cycles if you're in one of those situations where you're taking on water quickly. Personally, I'm not going to worry about it ... but depending on what your boating environment is like, you may want to consider something like @Leojay -- or one of the other recommendations you'll find on the forum.
That is correct that the bilge pump checks for water every 2 minutes. That does mean their is a delay between water reaching a pumpable level and the bilge pump starting to pump but I do not believe the delay is significant for any amount of water that the pump is capable of handling.
If you do need the pump to start faster just turn the switch off and back on. It checks for water as soon as it is powered on.
