I would have won MONEY !! on post #165 you can see the holes the dogs go into are all the way through the metal, I'd make sure you have the holes before you do anything else, thanks @kuwona for the picture
Yes you would have! LOL I do have holes for the dogs and they do go all the way through. They were just VERY corroded and built up with sand and god knows what else. Both plugs are now out and soaking in a solution of penetrating oil and water. The holes that they go in need some work as they are both severely corroded. I worked on the port side for a bit and got it shining nicely but the starboard was much worse (believe it or not). I want to say thank you again to all who have responded and helped me through this. I have seen post after post with folks having this very same issue and been petrified of breaking something. Now that I have them out (I think) I am in the clear. I will rebuild the bottoms, clean out the holes good, reseal the tubes, and with any luck have an amazing boating season free of having to worry about whether I can clean out or not.
Pulled it out. Originally I thought I was going to have to drill it out so I removed the screws and was able to yank the top. Once I realized how much force was needed I thought the bottom might come along as well. I returned the top to the bottom and screwed it all back in. Then pulled again and the whole port side came out. Rinse and repeat on the starboard; though it took way more force.
So during the process of pulling the starboard apart, the spring took to the air in a direction I did not catch. I cannot find the bastard anywhere. Does anyone have any suggestions for where to source a replacement for it. I am thinking one of the little spring kits from Lowes/Home Depot might have a close enough relative? Something like this: Home Depot Everbilt spring kit
ACE hardware near me has a bunch of springs in stock also. Look for a smaller hardware store near you, they may have loose springs available for purchase.
@Cobra Jet Steering LLC spent some time looking at the springs in the plugs....if I recall, he recommended putting in springs with more force - that are stiffer than the stock ones. I think his point was that a stiffer spring would possible reduce plug blow outs more. Now he'll likely say - just buy the cobra locks.
No matter what...remember to pull the plugs after every use, or you'll be back to square one.
For sure. I did buy the locks so it is mostly a non-issue. I just want to restore as much functionality to the original plug so will follow-through with a spring of some sort haha
I can attest to the effectiveness of the EZ Locks. Blowout was no fun, and I was aware of the possibility and janked pretty hard when I inserted the plug to make sure it was well seated. Blowout anyway. Never again after installing the EZ Lock. Money well spent.
