drewkaree
- Central WI
That looks great! I have a similar setup...it's going to stay damp under there, so treat anything that might rust. But a little preventative maintenance is totally worth the added secure storage.
I wonder if you could wire up an exhaust fan, using ductwork similar to your dryer ducting. They make inline fans, and it could definitely be wired to a thermal unit, or a humidity sensor. They make higher-powered radial fans as well, such as what's used in radon abatement, that would work even better.
Just a thought, sorry if I went on too long ?
