Strange fuses
Pro Build
South Brunswick, NJ
Where do you get fuses that look like this for replacement?
Just a guess, but they could be regular automotive fuses inside a black protective cover. Can you pull a fuse and see if maybe that black casing is just a cover? That first pic looks like the fuse box cover and its telling you what that fuse position controls. You can see one position is dock lights, another is tower lights.
Look like a breaker block not fuses, looking in my manual but cant find anything on it
Pretty sure they are standard fuses with a fancy top. I blew one and wondered the same thing. Was at the dealer that day and they just gave me a few of them for free. If you look closely they show the amperage on them if I recall.
Looks like relays to me, not fuses. Have you looked up a parts diagram?
Most of the boat electrical systems are on a fused based system, not relay. A relay is typically a time delayed switch based on voltage.
If everything is hooked up right on a AR240 2013, thats my boat, it all comes on once you turn on the battery switch.
The lettering and numbers on them do not make sense something like 1.2 K and other things, if you blow the picture up you can see themarkings. I'm not with the boat so I can't look for myself.,
When I saw 1.2k to me that means impedance, thus my assumption that it's a relay. I'm probably wrong though, cause my wife tells me so fairly often.... ;)
Where in the boat is the box located?
Doesn't look like the fuse box in the manual.
In the storage compartment that separates the cooler area from the engine compartment
If they are two prong they aren’t relays. My suggestion would be to pull one, turn the batteries on, and use a multimeter to check voltage to each side. If one side is 13v and one isn’t, it’s likely a fuse. That same multimeter can then be used to check the two prongs of said device for continuity and impedance. A cheap multimeter from Harbor Freight should accomplish this. $10, and it’ll save you miles of headache chasing electrical issues down the road.
They must be pretty reliable and durable if no one on this site has ever had to replace them.
Cool, so it's not something I need to be worried about under normal circumstances. Thank you.
You typically see very little impedance through a relay. It's either on or off and is an electrical switch. Resistors will have a color code that tells you their impedance.
Julian is correct. They are resistors. The 120 Ohm ones are termination resistors for the CAN/NMEA communications and the 1.2 k Ohm are for the lights.
Pretty sure I have the mystery solved.....they are resistors.
So are these resistors meant to blow if I did something stupid when charging my batteries? (I debated if I should start another post but decided to jump on this one) My stupid story: Over the last month batteries went dead in my boat while on the lift. Just bought batteries 10/2020. I bought Duralast Jump Starter and hooked up battery to try to get the boat to turn over. At one put during my attempts I switched the POS and NEG with the Jump Starter and battery. The boat horn beeped and (being stupid) I tried cranking the engine anyways. At that point I pulled both batteries and brought they to AutoZone where they charged them fully. Put the batteries back into boat and I get NOTHING when I turn the keys. I am hoping at this point these resistors saved me from stupidity? I see that the green 20amp fuses where blown. I switched the 20's but still nothing. My thought is maybe the black ones are blown but I am having trouble finding them. Based on what I did, is this fuse/resistor box the first place to start when trouble shooting or should I be looking elsewhere? Any insight would be appreciated.
From an electrical perspective, resistors are not a protective componant like a fuse is. A fuse is meant to protect a circuit from an over amperage situation. A resistor is meant to change the amount of current a.ong other things. Like when an led light needs 3v instead of 12v, a resistor is used to lower the voltage for the led.
Over current for a resistor usually means melting, and a burned electrical smell. You can check to see if they are ruined using a voltmeter as someone mentioned. You set it to impedence and connect the voltmeter to both ends.. It should match the number on the resistor.
Hopefully, you just missed a fuse somewhere and you get it sorted out!
In my boat, there are fuses by the battery...that is where I would start, fuses on the ECU in the engine compartment, and fuses in the starboard side under the seat. This is something would be good for someone to make a quick video of....
