usabas2
 - 212XE
2021 212XE. 155hrs
Eastern Oklahoma, Lake Eufaula
Noticed last season we had some power and speed loss. Did some reading so religiously avoid shallow waters and beaching.
Current symptoms and they just happened all of sudden…..
Day 1.
Boats running great we are scooting across the water 45mph top speed…did some tubing and wakeboarding no problems. Had 5 ppl onboard including myself.
Day 2.
Ran great all day same as above just outside marina no wake zone. Shut it down for final swim be loading out. Once back on board we took off and the boat would not go over 13 mph, nor plane, even as I worked to full throttle…no change but throwing massive wake…..thought to myself what in the world….just at that moment hit the no wake zone and shut it down.
Day 3
5 folks on board and it did the same thing out of the gate. Churning some serious wake, full throttle. Had everyone move to the front and the boat began to plane out and we finally sped up to 30mph. I stopped and pulled my clean out ports and checked the thrust gates with no findings. Checked my ballasts and they are empty. Eased on over to the swim beach let the kids out to swim, no tubing today. On the way back top speed 24mph and throwing some serious wake…lots of seadoos just going back and forth.
Day 4
Visually checked impellers, no dents or dings on either end. Pulled plug, some water did come out but not a worry some amount. Oil levels are spot and and the plugs had just been changed 4 weeks ago.
So now I am thinking wear rings. I can reach in and feel with my fingers scoring, but visibly it looks like some sand paper markings.
Questions….
1. What are actual the clearances that should be present between the wear ring and impeller?
2. Visibly the impellers have not dents or dings. If I do the wear rings should I just replace the impeller as well?
3. Is there something else I am missing?
Day 1.
Day 2.
Day 3
Day 4
Questions….
