Drift Away
- SX
If yamaha would just move it.up tothe next level of the swim deck it will work a whole lot better but I don't know how it work on some of the E-Series boatsThat sucks. I think that is a jog wheel so it is possible that there is still a waterproof barrier to the other internals. Only way to try amd prevent the corrosion would be to pack grease under the knob on a regualr basis and keep that rubber cover on whenever moving. If that is what happens after a season of salt water useage should be something others see after a few years of fresh water too.
Polk claims an IPX6 rating on that control panel along with salt and humidity protection. So it should be able to with stand high pressure water jets. They also list some specific other standards as well.
http://www.polkmarine.com/polk-ultr...-iphone-ready-bluetooth-with-app-control.html
Thanks for the heads up. This is something everyone should check and report back on. The reason is that if water were able to find its way to the internals from the knob it could cause Connext error messages, head unit issues, or similar with the JDAB networking either sending bad signals or no signal. Looks like a real PITA to remove the unit as well.
I talked to my guys at Cycle Springs here in Clearwater FL they said yamaha has a one year wrranty on them. I am thinking about having them replace then pull it out and replace it with this one from JL Audio. You lose the screen but might last longer. Or maybe even this one.Wow I'm seeing the value in remotes with sealed faces/soft buttons now. Does it have a limited lifetime warranty of some type that will allow you to exchange it whenever/if ever it causes you issues?
That cover does not stay on, at least in mine.Do you keep the rubber cover on it?
@Drift Away I think Yamaha put it on the lower swim deck so that if you are in the water you can still reach the controls without having to get up on the boat.
Are you planning on replacing the head unit at the same time? Pretty sure you'll have to stick with Polk unless you change out the HU.I talked to my guys at Cycle Springs here in Clearwater FL they said yamaha has a one year wrranty on them. I am thinking about having them replace then pull it out and replace it with this one from JL Audio. You lose the screen but might last longer. Or maybe even this one. View attachment 49156
Stays on fine with mine.That over does not stay on, at least in mine.
Good to know, I will be taking it up with the dealer than.Stays on fine with mine.
I took mine back to the dealer and they replaced the rear radio. When i got it back i pulled the knob off and put a squirt of spray chain lube. It came with another rubber cover. Since i had the one that came with the boat i started leavig it on while i running it. So far so good it has not came off yetAnyone have any update on this. I pulled my knob off and have rust on the spring but everywhere else looks good.
Yup thats how mine started. It fell off of in eventually and I ended up going to Lowe's and getting a dimmer switch knob that kind of fitView attachment 54528
Here is what mine looks like. The spring or retainer ring or whatever it is looks like the starting point. Think they would have used stainless. Oh yea that would cost something.
