SamCF
- Greenville, SC
- SX192
I picked up a SX 192 a few weeks back. The wife was pushing for the 190, but I got my way. I wanted the SHO because I knew how much potential it had.
I was very disappointed at first. It seems that heat soak is a big problem with these boats in hot climates. The boat would go 50 mph for less than a minute, then start backing down rpms until speed was down around 42-44 mph. This takes me to the first mod.
To address the heat soak issue and prepare for future performance mods, I ordered an intercooler and parts from Frozen Boost. I used one of their air to air coolers for a cummins project a few years back, and I'm very happy with their products.
Parts List:
Type 14 intercooler
3- 1/2" NPT x 3/4" barbed elbow
4 - 1" hose clamps
2 - 3/4" to 5/8" barbed couplers
2' - 3/4" ID water hose
1 - 3"x3" 90 deg silicone coupler
1 - 3"x2.5" 90 deg silicone coupler
2 - 3"x3" 45 deg silicone coupler
1 - 3"x3" 45 deg aluminum piping
7 - 3" hose clamps
reused hose clamp on supercharger.
The install took about 2 hours. I didn't hard mount the intercooler or run upgraded cooling lines at first. I wanted to test the setup before committing to it. I wrapped the bottom and back of the cooler in pipe insulation and set it beside the motor mount hump. Turns out it is very secure there and doesn't move at all while boating. After initial testing, I went back and tapped my coolant strainer and added a 3/4" dedicated line to the intercooler. (haven't tested this yet). The results were excellent. Low and Mid range power were much improved and top speed was 50 mph hitting the rev limiter. I ran it between 40-50 mph for over 10 miles and at any time I could punch it and hit 50 mph. Heat soak is GONE.
Here is a short video running 0-50 mph. Factory speedo lags quite a bit. GPS speed is in lower left corner of Nav unit.
I'm interested in R3 ECU, C3 Wheel and other supporting mods. If anyone has any ideas, please let me know.
This is top view including a cold air intake I threw together with some extra parts I had laying around.
Intercooler to Throttle body.
Supercharger to intercooler
Tapped Strainer
Parts List:
Type 14 intercooler
4 - 1" hose clamps
7 - 3" hose clamps
Tapped Strainer
