- North Caldwell, NJ
Looks great! What brand/model is it? Are you happy with how stable it is? Did you have to modify the bimini?
Thanks, Julian. This is an Origin Advancer tower, and I have a flat top-type bimini, swivel racks, etc. still being installed. Will post more pictures maybe tonight.
The tower is very sturdy, 2.25" diameter, nice welds, simple design. There is a couple of issues with the install not well covered in the instructions. The key is to tighten the top cross-horizontal bar to make the tower more stable. I used factory enforced hull mounting points, mounting inside the gunwales for the rear mounts is tough.
I have the same Advancer tower on my old ski boat and it has been great, it has stood up to some serious abuse, and it will not budge.
@swatski Do you have any pictures of it folded down? Just wondering if it will still fit in the garage?
@swatski So I don't need the support plates listed as #11 and #9 that are illustrated in the link? http://www.yamahasportsplaza.com/oemparts/a/yam/522f6159f87002303c9a9b56/wakeboard-tower
That looks really great. $500 for the tower is a screaming deal. What was the total cost with accessories?
Hello I ordered the same tower and installed on my SX192 but my problem is I followed instructions on your install and used the stock mounting spots which are reinforced like you said but the tower does not give enough head room to install the Bimini like u did ... I noticed looking at your pics that in the front you installed farther back from the actual reinforced panel , did you have any problems? I may need to redrill if I can't figure this out![]()
