Taking on water
@Holly Is it possible to get more specific about this? Which bolts? Where are they located? If this happened to yours it is likely to be a problem that others encounter.
Also, why isn't there a warning that you have THAT MUCH water in the engine bay? It can't be that hard to create
There is....it is called a bilge alarm. There are directions on how to install this and a fume alarm in my signature and the FAQ. I put a bilge alarm in my 2005, and will likely put one in the 242x this winter.
The bolts around the spot pictured. Mechanic said these boats idle hard and they probably just slipped loose and that it will probably happen again. They make bolts that lock and he recommending those. Taking it to the dealership tomorrow for inspection oil change and locking bolts. Very scary to know this can happen without much concern from dealer or manafactor. Probably caused some damage on engines. Too early to tell.
I have also installed a high water alarm. My sensor height is set at the top of my bilge pump. If water gets that high then trust me my boat will emit an ear piercing shriek that motivates one to action!
I would think a high water alarm would be standard, seems pretty important.
Holy crap! Bad picture and sorry to see that on a newer boat. Bilge should always be on and a second bilge is a mandatory mod IMO
Would loctite on the bolts help?
Glad you god it fixed but hate hearing about these kinds of downsides of jets. Is yamaha involved?
So went back to the lake today and had a mechanic look at it. Two loose bolts on the exhaust manifold caused this on a boat with less than 20hours wth.
I'm sorry I couldn't see the picture very well either, was he talking about the two bolts that screw into the circular clamps that holds rubber pipe on?
Holly, some of this is due to just not knowing the boat or boating in general. This would have been prevented if the bilge pump was on as one of the checklist items is to check the pee holes after start and first run, to see if you bilge is pumping anything. And earlier in the checklist, your supposed to check to see that the bilge pump is even working before you go boating. These are common practices. It sounds like you may have already gone back to the lake and run the boat, but that may have been a bad idea. All the water in your engine compartment...some may have been ingested by the engines into the intake. If that happens, you not only can get water into the oil but can hydrolock the engines and cause very bad damage. It is recommended any big water accumulation like that, that covers the engines as much as you had, that the spark plugs be pulled and the engines be turned over to expel any water that did get in. Its good your asking, but a general mechanic that isn't a Yamaha mechanic, may not know for sure. If he did, he would have said to check that first thing before starting those engines again. I don't know those engines or the air intake setup like I do the MR-1, but I know they can't get the air intake underwater as that will cause them to suck in water. I'm hoping all is well and the problem is found.
If you made it back to the dock, I doubt there was any engine damage. Lesson learned I'm sure. Change air filters and oil to be safe, but if you drove it to the dock you don't need to pull plugs.
