Chr2004
- Pensacola, FL
- Limited S
Update [HASH=460]#2:[/HASH]
We isolated the <exhaust> leak to the compartment aft of the engine compartment. It was obvious once we opened the clean out port cover where the exhaust was coming from. The resonator had melted. Pictures attached. The last people to work on the port side exhaust was the dealer.
Update: Thanks for all of the input!
We emptied the entire tank, cleaned it out, pulled port side injectors and cleaned them. We filled the tank with two bottles of sea foam Marine and 20 gallons of Shell 87 pump. Same exact problem. Ran in the water at idle for 30 mins smooth with no issue then 2K rpm no issues then 3.5K both engines struggle at the same time. Starboard dies after 15 seconds, port gives me about 30 seconds. Neither will re start unless you wait for about 15 mins. We are simply out of ideas.
Hello!
Going on 4 years of reliable boating with our 2011 242LS. For the first time the engines are giving me trouble. I changed the spark plugs and tested each engine for at least 5 minutes each on land. In the water (mom's only mothers day request was to go boating) port started fine and starboard had issues. Got it started and after about 5 minutes of idle speed both shut down. I tried re-start with no success. After about 10 minutes of letting them sit they both started with some hesitation and ran for about 5 minutes to get us back to the ramp. I let them run at the dock for about 5 minutes and decided to do another test at 2K rpm and below around the Marina. They both bogged at shutdown at the same time again. Looking to troubleshoot today.
I believe last fill up was ethanol free Murphy with Stabil storage about 8 months ago. I leave tank topped off.
Any insight would be greatly appreciated!!
Hello!
