Why should I not just tape my throttles together....WTF Throttlesync
Blenderhead
Spout Springs North Carolina
Malibu
Three questions -
Why is the throttle sync so expensive?
Why is the throttle sync so hard to find?
Why should I not just connect my throttles together (tastefully) with a home grown solution?
Is there any reason I should have individual control of my throttles? Am I missing something?
Speedling
Cedar Lake, IN
SS
One guy did a set of 3d printed things that dnapped on. Works decent. I have a big hand and don't care.
  1. Its a niche product with not much demand
  2. It is easy to find - Here, but perhaps you are asking why more people don't make it (see #1 answer)
  3. You could...or as Speedling says...just grab the middle of both handles and push....I never saw the need for it.
But I will say that the E-Series single throttle option is nice....I boat most of the time with "Single Lever" turned on, and turn it off when I am around docks and I like being able to adjust one side or another.
Blenderhead
Malibu
I got it but I guess I should have been more specific. Why a split double throttle? For what purpose? Am I not driving my boat as I should?
to address the list -
1. agree, niche product
2. all sold out (everywhere)
3. grab, both handles, big hands got it lol. (made me actually look at my hands)
4. wish the 212x had an E throttle
H2OBoy
Lake Oconee, GA
I recently went from the single throttle of an SX190 to the dual throttle of the AR210. I may be in the minority, but I do not like having to constantly adjust both throttles to maintain the same rpm. I just installed a Throttle Sync this weekend (thank you @sstegh) and it made a huge difference. I will likely never use the throttles independently again.
Blenderhead
Malibu
Boom!
Single throttle adjustment is what I'm looking for....but not for $150.
Cory
Lake Kiowa, TX 76240
I like being able to operate them separately when docking, loading etc.
There are lots of situations when using just one throttle has an advantage:
  1. If you only want a little forward momentum...just push one throttle forward
  2. If you want to spin (albeit slowly) in place, put one throttle forward and one backwards
  3. Rotating faster (somewhat) in place....throttle up the outside engine only...with the helm hard over
I'm anal, but I never really cared if one engine was running a little different RPMs than the other....this seems to bother some people.
Jebinok
Conway AR 72034
I can guarantee you if you have played with that "X" boat you have like it is capable you will never want throttle sync. Full speed run, cut the wheel, engine back on turning side BOOM, BAM, WOW thats fun, lets do it again. Of course the articulating keel Yamaha put on and ruined the fun with these boats take away from the spinning, IMO
mraz72
Rochester, NY
interesting on the dual throttles around the dock, I may have to play around.
I do understand what the OP is saying, because I thought the same, why would I want the engines out of sync, just one throttle for both engines.
arew~SX230
I don't care if the throttle sticks are lined up. I just want the engines turning about the same speed when traveling in a straight line allowing for wind, current, steering angle etc.. This is usually easily accomplished beyond 7000rpm, in "no wake" mode, and at idle. It is in the 3-5k range that my boat agravates the hell out of me and requires constant tweaking of one or both throttles. Pretty sure there ain't no sync for that.
justason
SWAG Forum Lead
biglar155
Fredonia, WI
Keeping in mind that I'm a tight-wad, I agree it's pricey. That said, I have it and I like it. I guess it just depends on how you drive your boat.
Like others, I keep mine unlocked around the dock for better maneuvering control and lock it once fully underway.
Size does matter and I appreciate the way the Throttlesync fits in my large-size hands.
At the end of the day it's a toy for a toy. I see things all the time that I'd personally never pay good money for - but they sell like hotcakes.
"Ya spends your money and ya takes your chances..."
Speedling
Cedar Lake, IN
SS
Jebinok
Conway AR 72034
@Michael Rasmussen if you haven't used you engines above idle at the docks? My My My, don't be scared to, you have a lot more boat than you know.
mraz72
Rochester, NY
These throttles are loose, and by loose I mean move very easily. I've already blasted my neighbor's boat with water while docking (it was covered and they weren't there) :)
I use single lever and I only correct, or blip, but boat speed isn't above idle while docking.
justason
SWAG Forum Lead
Still in the boat! Works decent but when i started getting used to boating more i liked the dual throttles and playing around with them. I find i can get that exact speed easier too. Clips on easy! I just put in a cupholder.
thanks @Speedling I don't use mine too much, my throttles are not perfectly synced. I've printed out your sync thread rebuild to redo mine ...someday...
Drift Away
Anyone looking for the throttle sync Cycle Springs in Clearwater Florida has five or six sets left. I was just there getting extra spark plugs and oil for the Bimini trip I think they were $155
