- Florida
- Other
- Other
I was asked if I would be interested in having a set of decals available for customers to add to their Ultimate fins, keep in mind they have to be a special decal called hi tack because of the decals being in the water.
My small decals are hi tack decals and they are more expensive than the regular type.
These decals would be placed on the plane side of the fins , since the fins are reversible you could place the decals on the 2 outside fins where they would show outward leaving the other side of the fins with the original decals and stampings facing inward.
This could also be done optionally on the inner fins on a twin engine boat if you so desired.
These decals would run about 20 dollars each so it wouldn't be all that expensive to do 2 or even 4 of the surfaces.
My question is basically do people want something like this?
I can also get them made for the magnum fins.
On a side note they also have the 7th hole position on them so if you have the early 6 hole fins you automatically know where to drill the 7th hole to upgrade them.
The concern I have is all this fang stuff is really taxing me.
I do everything myself so processing a 39 dollar A K fang order or a 40 dollar decal order is just as much work and takes just as much time as doing a steering order .
So honestly I was not all that crazy about doing this because it's the busy season and I have a lot to do already, but I decided to let you people give me feedback on this so I can decide if I want to go with it.
So what is the consensus ?
Keep in mind I am not installing them, that would be your job , A little soap and water with a squeegee. I wanted to post this here since I put it on another post without realizing It would confuse things. so I am going to put a link from that one over to here.
