Rod5
- Marietta GA
- 242X E-Series
Sub is on the sub chan of the 5000.5 amp which is way under utilized. The sub output at 4 ohms is only 200 watts, 2 ohms is 400 watts, and 1 ohm is 500 watts. The one factory sub is a 4 ohm sub. I added a second 4 ohm sub on the starboard side in parallel making the stock 4 ohm load a 2 ohm load and increasing or uncorking the amp sub output from 200 to 400 watts at only the cost of a sub. Here is the thread for more on this topic...@Rod5 Where is your sub hooked up on the amps? Seems too much for those amps.
https://jetboaters.net/threads/242x-stereo-how-to-exploit-free-unused-watts.13256/
