2021 FSH 252 Sport Thread
deubank1776
Ohio
252SD
TexAg-00
Howdy folks- long time lurker, first time poster. Finally took delivery of my 255 FSH Sport E! I’ve been out twice already and it really is an amazing boat! These have been lake outings but I have plans to drag it down to the coast (1hr 30 min away) for some offshore fishing. I’ll be sure and post pics and vids when I have some.
Anyway, (and maybe this isn’t the best forum for these questions), I have some upgrade questions for y’all. I’m researching the cobra jet drive things as well as a Minkota trolling motor (72” shaft). I’m also looking at putting XM weather on my Simrad. This will be my first upgrade.
QUESTION 1: So, to get XM weather on my Simrad, I believe I need to get the WM-4 module first ($500). Anyone ever installed one of these before? Easy? Better left to professionals?
QUESTION 2: I’ve seen some conflicting things on the trolling motor mount. I think we all agree that the 72” shaft is required, but what’s the consensus on the factory mount/plate that came with the boat? Will it work? Also, what about a quick detach mount? I only intend to use the trolling motor when fishing. Doable?
Thanks in advance everyone! This is my first post. Hopefully I can add value to this forum by answering future questions and posting vids/pics of any 255 fsh stuff!
TommyB
Ocean City, MD
I can answer the TM part. Factory mount works great. Really simple and fine. No need to reinvent. Quick detach bracket is a must. About $180. Min Kota RTA 54.
Zackdadams
MS Gulf Coast
I'm currently researching SiriusXM and weather etc myself.
I believe the boat comes with the Simrad 12 Go.
Therefore I don't belive it's compatible with the XM-4. (According to the specs for the 12 Go and the WM-4 separately)
Instead we will be using the SiriusXM WM-3 (with tri-cable) via NMEA2000 connection.
I'm currently installing the NMEA backbone on my FSH for future hardware.
TexAg-00
Awesome - great to know! Do you have this setup? Got a pic? Thanks again TommyB
TexAg-00
OK, sweet- thanks! This sounds like something I’ll leave to the professionals though. And while I’m very fond of my boat dealer, I often find we’re more educated than they are on these nuances. Anyway, a little bit of research never hurt anyone- so thanks for the info! Out of curiosity - what additional hardware do you have planned? Radar?
Oh- and a 3rd question popped up I forgot to ask yesterday. What’s the consensus on installing a fixed mount VHF in the recess area where an upper glovebox should be? Would it fit? Could required routing be discreetly routed to area under the console? Or is dash mounted (adjacent to the Simrad) our only likely option? If I’m going offshore, I probably want more power/range than a handheld. Thoughts? Thanks again everyone!!
TexAg-00
Radar, trolling motor, secondary transducer for side scan sonar, fixed Mount VHF radio possible (i use handheld now).
Ha! Exactly what I’m looking to do. I’ll be following your posts closely sir. Thanks!
Tranquility Base
HangOutdoors
Royal Oak, MI
TexAg-00
Thanks everybody. Yamaha did a great job w this boat.
TommyB
Ocean City, MD
TexAg-00
Beautiful! Exactly what I was looking for. Thank you!
A few questions: 72” shaft? Also, what battery do you go with? I assume they mounted it in the “changing room” below/adjacent to the amplifier? I’m thinking Lithium ion might be the ticket for my setup.
TommyB
Ocean City, MD
yes. 72. Perfect size even in chop.
group 26 marine batteries. I bought $100 ones from Napa and they’ve been fine. Noco onboard charger with charging plug.
considered lithium but couldn’t justify cost. And I’m not worried about 3 batteries on this big hammer. It can haul em no problem. Centered in changing room, forward.
TexAg-00
Perfect - thanks TommyB!
PerkDaddy
Melbourne, Florida
Took mine out for the second time yesterday. I launched from Ballard Park in Melbourne FL, drove south to Sebastian Inlet, then out to the wide Atlantic. The boat did great and everyone had a blast. Trolled and bottom fished but only had one keeper in the end. A Minn Kota would have been ideal for parking over reefs instead of guesstimating anchoring positions to drift back over the fishing spots.
Jdgars
FSH
Anybody happen to install trailer guide post yet on these 6” beam trailers? Looking for longer u bolts
