WiskyDan
- Jackson, WI
- 242 Limited S E-Series
So I bought a 2006 Yamaha SX230 at the end of last season and have it dry-stacked on Lake Winnebago in Oshkosh, WI. When I'm done with the boat I tie it up at the dock, put the mooring cover on, and away I go. What I'm concerned about is that since it's still in the water I need to leave the battery switch in the on position so that the bilge pump stays powered until they pull it out and re-rack it. If I'm only out on a Saturday it's possible the boat may sit at the dock until Monday morning which concerns me a bit since the battery will be discharging for what could be 36-40 hours.
I talked the the service guy at the place it's dry-racked at (they're a full service dealer) about a second battery and he feels that since I only have the factory stereo and a Garmin chart plotter/GPS drawing power that a second battery would be a bit of a waste. He recommends that they set it up so that the bilge pump is wired directly to the battery so that I can turn the battery switch off when I'm done to decrease the discharge. I spoke with the service guy at the Yamaha dealer where I bought the boat and he said that this would be fine - it's how he's seen some boats set up in the past. If I were to go this route I plan on buying a Noco Boost Plus GB40 and bring it with me whenever I use the boat - for piece of mind:
no.co
I don't have a problem spending the money to add a second battery (was told it would be about $500 from the dealer) but I'm not sure it makes economical sense to put it on an older boat if I plan to buy something newer in a couple years. Thoughts?
NOCO Boost Plus GB40 Jump Starter 1000A 12V – For Cars, SUVs, Trucks, & Motorcycles Portable Emergency Battery Booster Jump Box With Power Bank
The NOCO Boost Plus GB40 is a compact and portable 12V lithium jump starter that delivers 1000A of starting power to safely jump start dead batteries in seconds. Ideal for cars, trucks, SUVs, vans, pickup trucks, motorcycles, ATVs, boats, and more, it provides up to 20 jump starts on a single...
